flat rate time
   / flat rate time #1
ab72756
sw Missouri / nw Arkansas
varies regularly
How much labor (time) should I be charged for replacing two frost plugs and a pilot bearing on a 3000 diesel. The frost plugs were on the rear of the block.
   / flat rate time #2
About 1-1/2 to 2X the actual work time. The flat rate formula would start with the raw (actual) time required on a new tractor using hand tools, then add a used allowance (10%), plus time to get parts, a tenth of an hour to move the rig to the work bay, etc. When you consider all the time for these related activities you'll be ballparkish close.
   / flat rate time #3
Anyone that splits a 3000 and only changes two frost plugs and a pilot bearing deserves not to get paid at all. He should be kicked in the #** for not changing the third frost plug. There's two in the back of the block and one in the back of the cylinder head.
It's good practice to change the rear main crankshaft seal when the tractor is split, and probably to change the clutch release bearing as well. Soundguy would want the transmission input shaft seal(s) changed.
What about attachments? does it have a FEL, front plow, or other equipment that had to be removed prior to the split and reinstalled after? Did the shop that performed the repair truck the tractor? Did they have to spend an hour with a pressure washer to find the buckle up bolts? I don't like to get into billing disputes knowing half the story. And that's what this sounds like.
2013 E-One 95FT Ladder Fire Truck (A51692)
2013 E-One 95FT...
2016 Isuzu NPR Cab and Chassis Truck (A51692)
2016 Isuzu NPR Cab...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
New Holland B95 Backhoe (A50490)
New Holland B95...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
Shindawa EC7600 Concrete Saw  (A52384)
Shindawa EC7600...
