Flat all winter
/ Flat all winter #1
Mike1955
Platinum Member
Kubota
On my Kubato 1100 side by side one of the tires stayed flat all winter. I air everything up and now it seem like that tire isn’t round any more. I think I know I need a tire but is there anything I can do to make it rd now.. it’s a bouncy ride now. I imagine that was a 150 dollar mistake
/ Flat all winter #2
Get the tire warm and may flex back to being round. Maybe add a few PSI extra air pressure to aide in reshaping tire when warm.
Yes rough ride till they get round again.
/ Flat all winter #3
Inflate to sidewall maximum+10psi and drive slowly in hot weather. The tire cords will re-assume their normal shape.
Carlisle Tire says 10psi extra is OK at lower speeds.
/ Flat all winter #4
I've had tires that were flat for years. Overinflating a bit and warm weather helps a great deal.
/ Flat all winter #5
I put a shot of sealant in all my seasonal tires.
Minimizes air loss over the winter in all my ag and RV tires.
Won't help now with your out of round tire but it can keep the problem from happening again
/ Flat all winter #6
My mower tires have flat spots every spring. The cold weather causes pressure drop (physics), and sitting in one place on the (assumed) bias ply tires is a known issue. But they're always back to their regular round self after one mowing session, in fact probably within the first 30 minutes.
I disagree on Ray's idea to inflate to max PSI though. I suspect running on them at a more normal / lower pressure is more likely to exercise the flat spot out of them sooner, than stiffening them up by running max pressure. Of course that's a wager based on reasoning, and not actual experience of having tried both methods.
/ Flat all winter #7
When the tire gets warm and you drive it around for a while the tire will get round again and stop making you bounce around. Add some slime afterwards inside the tire and all should be good.
/ Flat all winter #8
How will that Slime prevent colder weather pressure loss? As WinterDeere said, nothing change the laws of physics.
Goodyear states results of the law of physics for this:
How Cold Weather Can Affect Tire Pressure​
For every 10 degrees of temperature drop, tires will drop 1-2 pounds of pressure. It is important to keep your tires within the recommended PSI to maintain traction, handling and durability.
/ Flat all winter #9
Won't prevent some loss, but it will keep the tire from going completely flat
That was the OP's problem.
/ Flat all winter #10
Yup, allowed to remain flat for an extended period can ruin the sidewall plies and belts permanently.
I forgot that happened. I guess I allowed my aversion to Fix A Flat to color my opinion; it will cause so much rim damage and mess, most tire shops will not work on a wheel with that added.
/ Flat all winter #11
Slime is supposed to stay gooey, to be wiped clean next time the tire is off the rim, so a bit different than Fix-a-Flat. Also, tractor tires don’t need careful balancing, like automotive tires, so less a factor.
I’ve never used either, but I’ve seen the result of both in tires from others. It might not be a bad solution, here.
My usual method is to hunt for any potential bead leak with soapy water, and then once found, pop the bead, clean the tire and the rim with Scotch Brite or fine sandpaper then use bead sealer. If that fails, then I usually resort straight to a tube. Call me “old school”.
/ Flat all winter #12
Not sure about Fix A Flat, but Slime is water soluble and easily washes away. I've been using it for years and have had to work on tires & rims a few times. A garden hose quickly cleans it up.
It's difficult to patch a Slime filled tube though. I usually don't bother and just replace the tube.
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
7002SFL (A61572)
7002SFL (A61572)
2009 Peterbilt Pac-Mac KBF-20H Forestry Grapple Truck (A64556)
2009 Peterbilt...
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A64553)
2025 Mower King...
