Oil & Fuel Flashing oil light
/ Flashing oil light #1
dore618
Middletown, NY
Cub Cadet 13RF91AP056
Hi --
I'm not sure if I am posting in the right area. I own a Cub Cadet 50" lawn tractor LTX1050KW, model number 13RF91AP056. It has just reached 100 hours of use and the oil light flashes. When it comes on a code appears on the screen "CH6". Does anyone know:
1) Where I can find the list of diagnostic codes for this machine and/or...
2) What does that code mean?
The machine appears to be running well, but I am concerned about this flashing oil light. I don't want to damage it.
Could this be a maintenance light.
Thank you for your anticipated help. Tom Dore (E-mail -- tandjdore@yahoo.com)
/ Flashing oil light #2
The diagnostic codes will be listed in your owners manual.
Good luck!
/ Flashing oil light #3
I found this in an old post from 2008. The "6" is apparently supposed to be a "G".
This is the COMPACT Tractor board. Normally you should post in the LAWN & GARDEN forum:
Here's what the manual says about the oil change indicator on the hour meter.
The LCD will alternately flash the recorded hours and CHG and OIL for five minutes after every 50 hrs of recorded operation. The maintenance interval lasts for two hours(from 50-52, 100-102, 150-152, etc). The LCD will flash as described above for five minutes every time the tractor engine has been started during the maintenance interval.
Bob B.
/ Flashing oil light #4
Bob B.
Bob took the words right out of my mouth.....:D
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
ATS 40 Gallon 2 Stage Air Compressor (A62679)
ATS 40 Gallon 2...
Towable Generator (A60352)
Towable Generator...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
2007 KOMATSU PC35MR-2 TRACKED LOADER EXCAVATOR (A59914)
2007 KOMATSU...
