FLASHING LIGHTS
/ FLASHING LIGHTS #1
mac10
HI i am new to this sight and seen there was a kubota only section so i am reposting it here.... has anybody ever had this happen to them. i have a new b-7800 and i look out side and the 4 ways where flashing by the time i got out side they where off. i went back in the house and about 5 mins. later they where on again i thought some one was screwing with me but the button was not pushed. any thoughts????
THANKS
/ FLASHING LIGHTS #2
Interesting problem - never happend to me but I just spent a whole day wiring up worklights (should have been a 1 hour job...) and I got more familiar with the electrical system than I wanted to. You must have a loose connection somewhere - tried jiggling the switch? Or tracing the wire back to the fuse block - maybe the fuse is loose?
Snoho3
/ FLASHING LIGHTS #3
It happened to me on my BX23 when I first got it three years ago. The dealer had it outside for a number of months before I bought it and the switches are not watertight. It took me a couple of events like yours, but after blowing out the switch, and storing it under roof it has not happened again in over 2 1/2 years.
FRAN3
/ FLASHING LIGHTS #4
Yep its the switch those switches are not water tight and water just makes em go crazy. You can take em apart and clean them. They just snap apart.
/ FLASHING LIGHTS #5
Got so sick of it flattening the battery that I removed all wiring from the flasher and head light switches.
The switches get moisture in them and the electronic control ccts go crazy.
/ FLASHING LIGHTS #6
Spray some silicone lube in them.. it displaces water..
soundguy
/ FLASHING LIGHTS #8
The wd-40 seems to evaporate pretty fast though.. A few days after spraying and it's gone... that's why i use the silicone lube for dewattering.. seems to stay in place longer. But Yeah.. both work well for the intended purpose.. etc.
soundguy
/ FLASHING LIGHTS #9
Don't use WD40 - it'll attract and hold too much dust, then you'll have all sorts of problems. Silicone spray shouldn't attract as much dust, but it still may attract some. Dust is as big a problem on those switches as water is.
Best thing to use is an electrical parts cleaner in a spray can that you can get at any auto parts store. Once you get it cleaned up, and if you don't store it outside without a cover, your problem should be pretty well solved.
/ FLASHING LIGHTS #10
Even with a cover.. humidity and condensation will get to it.
I'm a fan of sealed, greased filled, marine grade switches for this reason.. etc.
soundguy
/ FLASHING LIGHTS #11
soundguy
Can't argue with that - those switches are great.
/ FLASHING LIGHTS #12
Dielectric grease. It will keep the water displaced. It's recommended by/for collector car electric switches. An auto parts store should have it.
/ FLASHING LIGHTS #13
They cost a bit more up front.. but the fact that you don't have to replace cheap switches every couple years is nice..
soundguy
2014 Chrysler 200 Sedan (A64557)
2014 Chrysler 200...
2000 Ford Windstar Van (A64557)
2000 Ford Windstar...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
TAKEUCHI TB260 EXCAVATOR (A65053)
TAKEUCHI TB260...
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
2006 Heil DOT 406 Comp Fuel Tanker (A64194)
2006 Heil DOT 406...
