Flashing dash lights
/ Flashing dash lights #1
D&D
Veteran Member
KIoti, JD, Kubota
My DK5310 would not start this morning, 20 F. Dash lights on, turn key, nothing. Went and got a jumppack, dash lights on, turn key and very light on the dash is now flashing. Tested battery and it has a bad cell (or two?). Came back with new battery, dash lights on, turn key and it starts.
From reading, all dash lights flashing is a critical systems failure. DTC codes will hopefully lead you to which critical system is dead 🤷‍♂️
Just a heads up post because I’ve never seen this before on any brand.
/ Flashing dash lights #2
I read a thread several months ago about low or bad batteries frying ECM's due to low voltage / high amperage through the circuit board.
It was concerning enough that I swapped out my 10 year old battery that had been cranking slower than usual.
Hope you get it straightened out.
2018 Ford F-150 Crew Cab Pickup Truck (A61568)
2018 Ford F-150...
Champion Vibratory Roller (A60462)
Champion Vibratory...
New/Unused Landhonor Transfer Pump (A61166)
New/Unused...
UNUSED SDLANCH SDLFP30 EELCTRIC PALLET JACK (A62131)
UNUSED SDLANCH...
Case skid steer wheels and tires (A63118)
Case skid steer...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
