Flasher lights on JD 4110 rollbar
   / Flasher lights on JD 4110 rollbar #1
tld
Boston, GA
JD 2025r
In the process of hitting some tree branches I have lost one of the bolts attaching the lights to the rollbar. I can get the bolt from JD no problem. However the bolt is threaded into a knurlled fitting that is pressed into the plastic light assembly.
Of course the knurelled fitting is gone also. Only way to get that is to buy the light assembly. Any ideas?
   / Flasher lights on JD 4110 rollbar #2
I had the same problem on my 4010 /forums/images/graemlins/shocked.gif. I removed the lens cover, drilled "thru" the area that held the knurled "nut" to the inside of the housing so I could install a longer bolt in place of the original bolt, and a washer and nut inside the housing. This required slightly bending the light fixture located inside the housing. Instead of the bottom edge of the fixture resting in the recess in the housing, I bent it so it has pressure against the bolt threads, holding it in place. Hope this helps.
Rick
Mack Fire Truck (A50860)
Mack Fire Truck...
2018 John Deere 524K-II Articulated Wheel Loader (A50322)
2018 John Deere...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
2013 BMW X3 AWD SUV (A48082)
2013 BMW X3 AWD...
2022 Club Car...
