Flail vs. Bush Hog..?
   / Flail vs. Bush Hog..? #1
wetstuff
Salisbury, Maryland
J-D 1070, Furgeson F-40
I understand horizontal vs. vertical .. bigazz blades vs. tiny blades, etc. I simply do no know when you would pick one over another.. I'm sure many of you know and can enlighten. (I have both, 72" BH and Finish mowers)
Thanks.
Jim
   / Flail vs. Bush Hog..? #2
Thanks.
Jim
the finish mowers are used to mow your lawns,an areas you want that mowed lawn look.bushhogs are used to shredd pastures an keep them looking nice.
   / Flail vs. Bush Hog..? #3
I think he wants to know when you would select a flail mower vs a bush hog or finish mower...
I can't answer that question. I know that my neighbor uses a flail mower to cut hay but I never asked him why. I assume it's because the flail doesn't fling the cut grass all over the place...it stays more or less in nice straight rows.
   / Flail vs. Bush Hog..? #4
Flail uses many more blades, cutting the vegetation finer and therefore looks much better but does not handle very thick or tree like brush well at all. Shredder does not cut grassy areas as cleanly but will cut down thick and brushier areas. I have used both many times and a flail does a great job in the field as long as their are no very thick areas or brushy vegetation. They are both very good at what they do. I prefer a shredder. If you keep the blades sharp it will do a good job of cutting grassy areas. Maintanence on the shredder is also much easier.
   / Flail vs. Bush Hog..? #5
Flail mower
>two types of (knives) blades, rough or finish cut
>smoother, golf course-like finish
>takes more HP to run
>safer since it doesn't throw objects
>cuttings seem to disappear, no windrows
Bush Hog
>will cut heavier and thicker material
>blades cheaper and easier to sharpen/replace
>very rough cut especially with dull blades
>heavier blades will keep moment of inertia and cut brush but still swing out of the way if necessary
>less moving parts/bearings to replace and maintain
I usually make the first cut in spring with a Bush Hog set at 6" and then go over it a few days later with a flail set to about 3". It looks lawn-like as a result.
It seems like all of the long weeds flatted by the tires and later standing back up are taken care of with the flail.
   / Flail vs. Bush Hog..? #6
There are some pretty lengthy threads on flail mowers on the "Attachments" section. Leonz has provided me a lot of good information on the flail mower as have others with experience.
I will remain with the bush hog/rotary cutter/shredder as I have to mow areas where you simply cannot use a flail such as backing over the edge of drop offs, ditches, under trees/shrubs etc.
I must admit that from time to time I am tempted to get one though I would keep my bush hog/rotary cutter/shredder.
We get a really nice looking cut with our Woods DS1260 and the Land Pride RCR2672 does a pretty good job though I am sure the flail gives a more finished appearance.
We will mow grass/weeds/saplings all in the same day and it is just too much trouble to change implements.
Thanks gentlemen.. I have a 5-6ac "pasture" that is basically a front section out in front of the woods that I attempt to keep somewhat civilized Spring-Fall. It's chocka Gum and Maple saplings, weird weed, ground bees and a pinch of grass. I typically hammer it back down about once a month.
We thought about a number of ways to keep it fresh and pretty, but my wife says; she's not up to tending 5ac of blackberrys, or a herd of goats/sheep/chickens/etc. I don't see the sense in simply killing it all off and starting with lespedeza hay, or some such without putting in irrigation... not for 5ac.
I forgot - all the contractors who cut shoulders for the county use Flails. Probably so they don't get daily lawsuits from motorists who need a new paint job for their precious '82 Olds.
There was a flail available locally for $1k .. looked interesting. Money will look more interesting in my pocket. Thanks again.
Jim
   / Flail vs. Bush Hog..? #8
Jim
We have some areas similar to that and have been using Cross Bow herbicide. We have had some success broadcast seeding.
For bigger areas, we have a no-till drill or get a special planter from ASCS to put in Big Blue, Indian Grass and such. It does take quite a bit of work or some bigger equipment to do this right though.
   / Flail vs. Bush Hog..? #9
FYI. I like Crossbow,too. I stumbled upon a generic Crossbow called Crossroad; however, I haven't seen it packaged in 2.5 gallon containers. I'm thinking about buying a gallon to see how it works. The link below gives a price of $50/gallon, but I thought I saw it listed for a lower price elsewhere.
Crossroad Brush Killer 1 GAL Replacement for Crossbow on eBay!
Steve
   / Flail vs. Bush Hog..? #10
Steve
Thanks, I will check into it as Crossbow is expensive.
I had been using LV400 for years and it just seemed hit or miss on some things. I get a lot of really great advice from farmers and one day while speaking to the man who rents our land noticed he was using Crossbow and asked him about it. He is 82 and been farming a long time and just about seen it all. He is one of those guys we are losing all too quickly now, truly one of "The Greatest Generation". It sure beat the heck out of anything else I had tried.
I will try to find some of that Crossroad and give it a shot as it is sure cheaper than Crossbow. I am guessing it is also safe for grass? We also use another brush killer that kills EVERYTHING. It is not a glycosphate base I don't think. If it works out, I will tell Vincent and we can all save some money.
2018 DIAMOND C 40 FOOT GOOSENECK (A53843)
2018 DIAMOND C 40...
2005 TerraGator 8104 (A53473)
2005 TerraGator...
MISC WRENCHES (A53843)
John Deere (A50322)
John Deere (A50322)
2005 YALE 5K FORKLIFT (A53843)
2005 YALE 5K...
2010 CATERPILLAR D6N LGP DOZER (A51406)
2010 CATERPILLAR...
