Mowing flail mower
   / flail mower
Thanks! I was hoping to keep my limit under $2K--so,maybe I'm not being too unrealistic.
   / flail mower #12
I don't think 2K is unrealistic. I'd check some prices on a good rotary cutter ~1000-1500 range and then check into flail's as to size and general comparisons. I've seen many a fields cut with like a rhino or a woods/jd rotary and it looks realy good I use a finishing mower myself setup about 3.5-5". I know i seen a ton of flail mowers in nc from state mowing i honestly have never seen one used in tn or at dealer eather i guess were too cheap over here?
What happens when flail mower hits a rock stump or something else like that do they jump up or roll over it or wam bam? I seen a picture looks like little cutting discs in place of tiller tines like on tiller?
   / flail mower
</font><font color="blue" class="small">( )</font> What happens when flail mower hits a rock stump or something else like that do they jump up or roll over it or wam bam? </font><font color="blue" class="small">( )</font>
Good question, I'd also like to know how they handle rocks..not that I plan to mow rocks, but those buggers seem to grow after a good rain here in NC! /forums/images/graemlins/crazy.gif
   / flail mower #14
Tony,
Agri-supply in NC sell a Caroni 73 " flail mower for $1300 in the catalog. I'm sure they have smaller ones. They have 3 stores, in Garner, Greenville, and Lumberton.
   / flail mower
Thanks, Jim! I will check into that. /forums/images/graemlins/cool.gif
   / flail mower
Jim,
i checked in Agri-Supply...they do have smaller mowers, 47" and 59" I believe. I noticed, however, the HP rating for even the 48" model is 20-40 HP. I've looked at some other brands of similar size and weight, and those are all rated at 15-40 HP.
I'm wondering if my 18-19 HP yanmar will pull this thing--I'm also concerned about weight..it's around 468 lbs, about 240 more than my rototiller!! /forums/images/graemlins/shocked.gif
thanks
   / flail mower #17
Tony, we just put a 47" Caroni behind a YM1610D and it handled it with no problem. The tractor has a loader on it, so the rear weight is no problem either.
   / flail mower
Thanks, Dave! My tractor is a 1401d with about 100 lbs. up front..do you think it would be suitable?
   / flail mower #19
Tony, it would be marginal. You would want more weight up front I think. A loader is great ballast /forums/images/graemlins/smile.gif. It would probably mow OK, but if the grass/weeds were long and/or wet you might have to go very slow.
   / flail mower #20
How big a one could someone put on a agco 5020 4x4 20 pto ~24 engine hp weights about 2200# around size of 2000 or so i quess? I tried to look at flail mowers but never could find anything other than parts any page #'s ..
2006 Wells Cargo 8x16 Trailer (A55973)
2006 Wells Cargo...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
2015 CATERPILLAR 323FL EXCAVATOR (A52707)
2015 CATERPILLAR...
TORO TRX20 STAND ON TRENCHER (A52707)
TORO TRX20 STAND...
UNUSED SDLANCH SDL25 RIDE ON DUMPER (A57192)
UNUSED SDLANCH...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
