Flail mower
   / Flail mower #1
479Scaper
Fayetteville Arkansas
ASV 4500HD, ASV RC100
New member so if this has already been discussed let me know, recently converted a Tiger flail mower to quick attach to my skid steer, would like to install a better performing hyd.motor. I have two high flow machines one is around 20gpm and the other runs in the low 30's. This flail was designed with a 44gpm pump running at 2000rpm or so. Thanks for any input
   / Flail mower #2
Welcome to the forum,
The only way you will be able to do
this is with a vane motor.
The issue is one of motor mounting.
You will need to match the mounting
plate with the hydraulic motor face plate.
If you are using a gear motor zero issues-but
if you are using a geroller...................., some
machining will need to be done.
The vane motor will also be able to reverse
direction for you as needed.
I can recommend the Vickers brand vane motors
very highly as they wil have high torque
which is needed for a hydraulic driven flail mower.
:thumbsup:
   / Flail mower
Thanks for the input, will look into Vickers. The flail is a 75" cutting width with 45 sets of blades, so you are correct about needing torque.
2015 INTERNATIONAL PROSTAR TANDEM AXLE MID ROOF SLEEPER (A52577)
2015 INTERNATIONAL...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
Ditch Witch 350SX Diesel Ride-On Hydraulic Trencher (A50322)
Ditch Witch 350SX...
