Mowing flail mower vs. bush hog
   / flail mower vs. bush hog #11
Landpride also makes some good Flail Mowers Landpride
Andy
   / flail mower vs. bush hog #12
Thanks for the info Bird,Golfgar4
Chris
I do have one more question. Will a flail mower mow a pasture that is slightly overgrown? If I let it grow to 6-7" can I cut it back to 3" without overloading?
   / flail mower vs. bush hog #14
</font><font color="blue" class="small">( Thanks for the info Bird,Golfgar4
Chris )</font>
Yes easily if you have enough pto hp and the right blades in the flail mower. For only 6-7" the standard blades should be fine and I don't think the ho increase would be much depending on how wide you went. Many golf courses use flail mowers for some of their mowing.
Andy
Andy,
Thanks, sounds like it will do everything I need.
   / flail mower vs. bush hog #16
Interesting thread! When I was purchasing a tractor I too was interested in a flail mower. However, I couldnt find anyone who would recommend them. The reasons were high initial cost, high cost of up keep, not as good a cut as a conventional mower. What I could never get an answer for was what are the high up keep costs. No one I talked to could answer that one. So, what are they?
It seems that flail mowers would be more flexible than rotary types b/c w/ a changes of blades (or hammers...is that what theyre called?) you could have a mower suited for a wide range of situations.
   / flail mower vs. bush hog #17
I think you'll regret purchasing such a small-width machine. You will be at it a long time if you're mowing 6 acres with a ~5 ft deck. A TC 35 should be able to handle 7 ft. I'd opt for a 6 foot deck as a minimum.
I keep changing my mind on the width I need for two reasons. 1) I have a number of trees that I need to mow around/between on part of the property. 2) The ground is uneven in many places.
I do have a large fence line and like the offset feature of a flail mower that would allow me to get up close to a fence.
Does anyone have a "rule of thumb" as far as how much land you can mow in an hour with a certain width mower?
   / flail mower vs. bush hog #19
I think I read on one of the other sites that the recommended max speed is 5 mph. This might help in determining the amount per hour of cut. If I am wrong about the speed someone please correct me. Joe
2018 Kia Optima Sedan (A55973)
2018 Kia Optima...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2017 FREIGHTLINER M2 106 (A55745)
2017 FREIGHTLINER...
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
UNUSED PABREAK BE232 HYD BACKHOE DIGGER ARM (A57193)
UNUSED PABREAK...
