Flail mower slip clutch/sheer pin question
   / Flail mower slip clutch/sheer pin question #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
I did not want to add this to my other post since it was a bit different question than what I originally posted.
My question is should a flail mower have a slip clutch or a sheer pin? The one I recently got does not and I am not sure if there should be one. One idea what that there is in internal clutch or the idea is the belts just slip if something jams up?
(mine is a Taylor Turbomower 64 if that matters)
THANKS
   / Flail mower slip clutch/sheer pin question #2
It should have neither. The belts are your protection. Make sure they are tensioned properly and that the spring tensioner moves freely(if it has one).
Bill
   / Flail mower slip clutch/sheer pin question #3
Slip clutch is an unnecessary expense, the flail belt(s) will slip before a properly adjusted clutch slips. But definitely go with an appropriate grade shear pin (I'm guessing SAE grade 2 or metric class 4.6). It will protect your tractor against a catastrophic lockup of the flail on the transmission side of the belts.
//greg//
   / Flail mower slip clutch/sheer pin question #4
As mentioned by my friends Hooked on HP and Greg_G no slip clutch is needed.
You should have a shear pin located in the base of one or both of the Yokes if the PTO shaft has them BUT;
The V belts are your actual safety valve.
Just be sure to purchase the right replacement Kevlar V belts now AND be doubly SURE that they are the same manufacturing lot number. take the belts to NAPA, TSC, PEP BOYS, Menards, KAMAN etc if they are illegible(stampings gone in the belt cover) and they will get the right belt for you.
_________________________________________________________________
Once you go flail you never go back:thumbsup::licking::drool:
Pronovost or not at all!!!:thumbsup::licking::drool:
Thanks all!!!
At least I know it is correct to start with. I will check my belts and go over it all today!
Thanks for all the help!
   / Flail mower slip clutch/sheer pin question #6
Hello Scott,
If your Bomford Turner is one of the three
in the manual that I e-mailed to you it
will weigh 750 to 850 Kilograms;
You may want to purchase front weights for
the tractor if the rears are not loaded.
Welcome to the Flail Mower Nation "Changing the world one flail mower at a time"
Here is a photo to help explain what I am talking about - it is a little bigger than most of the ones I have seen s far.....
2018 CATERPILLAR 336FL EXCAVATOR (A52141)
2018 CATERPILLAR...
UNUSED FUTURE MINI SKID STEER STRAIGHT DIGGING ARM (A51244)
UNUSED FUTURE MINI...
2019 JOHN DEERE 317G SKID STEER (A51242)
2019 JOHN DEERE...
2017 Ford Expedition SUV (A50324)
2017 Ford...
IH 1300 Sickle Bar Mower (A50515)
IH 1300 Sickle Bar...
2016 CATERPILLAR 239D SKID STEER (A51242)
2016 CATERPILLAR...
