Mowing Flail Mower on BX24
   / Flail Mower on BX24 #1
turkeyvulture
Anyone try a flail mower on a BX24? I found one that's 1800 pounds, way to heavy. Aware of a lighter one?
   / Flail Mower on BX24 #2
Ford had one that was five ft. long. It was perfect for my L245DT. Not sure of weight on that unit. With the number of BX24's and others that size out there must be something available. Probably pricey as well.
   / Flail Mower on BX24 #3
I'm sure you could source a 48 or 52 inch machine, check out some of the European manufacturers like Caroni or Maschio. Once you go flail, you'll never go back...
Cheers
Roger
I finally broke down and got the 60" mid mount. Lovin it so far, I just leave it on there. In heavy stuff, I mow with the mid mount and rear rotary at the same time.
2006 PETERBILT 379 (A58214)
2006 PETERBILT 379...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
Mini Skid-Steer Steel Mounting Plate (New/Unused) (A59225)
Mini Skid-Steer...
LOT LOCATIONS (A58018)
2013 Ford F-550 Ambulance (A56858)
2013 Ford F-550...
2017 FORD F550 CAB & CHASSIS (INOPERABLE) (A58214)
2017 FORD F550 CAB...
