Flail mower for MX5100 (42hp PTO machine) thoughts
   / Flail mower for MX5100 (42hp PTO machine) thoughts #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
I was wondering if anyone is running a flail mower on a MX5100 (or close to it) and wondering how it does with whatever size you are using.
I found an 90" Motts/Alamo flail I am interested in and didn't know how my machine would run it so I was looking for some real world experience (I have a hydro so my PTO is 42.5hp I believe)
Thank you
   / Flail mower for MX5100 (42hp PTO machine) thoughts #2
I run a 72" Mott flail mower with my mx4700. It runs it great. Of course it depends on what you'll be cutting, but I think a 90" on your tractor would be just fine. That's the beauty of a hydro tranny in my opinion. Sure you lose a little HP, but if the grass gets a little thicker, you can just slow down to where the engine is keeping up with the material you're cutting. I certainly wouldn't hesitate to run a 90" flail on mine and you have about 5 more ponies than I do.
Good info - thanks. I thought I could run it and for the most part I can can just not cut as wide if needed. I mostly mow about 3 times a summer so nothing over 20-24" and mainly just weeds mixed with grass. - not sure dense.
What kind of knives/hammers do you use and how does it work on brush?
   / Flail mower for MX5100 (42hp PTO machine) thoughts #4
Mine has grass cutters on it. Each flail is two pieces side by side about 3" long that bend out 90 degrees at the end. So the effect is like an inverted "T" when it's cutting. It cuts grass and weeds pretty good. Almost a finish mower cut, but not quite. Better than the bush hog, though. It's not real good for stemmy weeds or brush, at least not with the cutters that are on it. What's the price tag like on the one you're looking at?
They want 850 but think I can get it for less. It is in fair shape cosmetically but seems mechanically sound. Every once and a while one comes up at auction around here and they sell CHEAP - often $300ish but I have not seen anything recently (of course)....
   / Flail mower for MX5100 (42hp PTO machine) thoughts #6
I had a 72" flail several years ago, I thought it cut very well. Don't remember the brand. One thing you need to look for is if the drum is balanced. I didn't & it cost me a $1000 for a new drum. If you start getting into brush, be carefully as you will start knocking off blades, another real world experience. I pulled it with a 45 PTO HP Case which I still have. Wound up selling flail for scrap when it was more trouble / maintenance than it was worth.
   / Flail mower for MX5100 (42hp PTO machine) thoughts #7
My L3200 pulls a 72" old Ford 719 flail well. I have to slow a bit in thick grass, but not bad. Your bigger machine should have no problem.
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
1999 MATE END DUMP TRAILER (A52472)
1999 MATE END DUMP...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2023 EXA INDUSTRIAL EXA INDUSTRIAL (A52472)
2023 EXA...
