Flail mower drive
   / Flail mower drive #1
joes_427_vette
Veteran Member
Midwest
IH Cub Lo Boy, 955 John Deere , TC 55 DA New Holland, Bolens HT 20 and 1456
Bought a used 6' flail mower with a broken gear drive. Apparently the small alum housing didn't hold alot of oil and the small offset gear arrangement ran dry. A new gear drive is very expensive and by counting the teeth it is geared 3 to 1 on the pto. I have a new holland 1 to 1 gearbox with pto shaft that fits like it belongs. There is not enough room at the drive shaft to get the proper speed with a large pulley. Any ideas how to get the proper speed ? It cuts short grass 1 to 1 but not heavy tall grass.... needs the rpm for a clean cut.
   / Flail mower drive #2
Don't know much about the NH equipment, but I wonder if a different gear set could be installed in that NH housing? Maybe a check with NH engineering could help? Sure would be nifty if that worked out for you.
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
1269 (A50490)
1269 (A50490)
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
71056 (A49346)
71056 (A49346)
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
