leonz
Super Member
Hello Ricn,
If possible please ask them to provide you with full written information about the three control valves as somebody wearing orange is blowing smoke here.
There is the possibility that the common relief valve pressure for all three valves is set to low BUT they could should have told you that up front when all this started.
OK,
1. so you have one pair of remotes for the differential cylinder/slide cylinder
2. the second pair of remotes is for the top and tilt circuit
Where is the third remote in all this? IF you have 3 separate pairs of remotes with a total of 6 steel hydraulic lines plus
the hydraulic circuit for the lower link arms which is usually the outer hydraulic valve handle on the console making a total of four hydraulic circuits.
The lower link arms hydraulic circuit was supplied with the mule when you bought it and is fed from the oil sump of the mule.
I just hate it when a simple fix like checking the common relief valve pressure requires them to remove your mule from the property--not needed.........
If they did not set the relief valve spring pressure high enough its entirely possible that the weight of the mower is forcing the relief valve cartridge spool open and draining oil back into the tank.
If they have to remove the seat and all the extraneous mounting plates to access the steel lines and the control valve spools and the common relief valve I could see them taking it but they should have told you what they were going to do to begin with rather than just saying we want it, we want to take a look at it, which tells me they don't know what is going on with it period.
I just want you to have a mule that works. Please PM me when you know more as it does not sound like its going to be a simple fix as you would have trouble with the entire hydraulic system if the relief valve was set to low.
Its entirely possible that a piece of dirt or metal shavings is stuck in the control valve which would affect the circuit and allow it to bleed back to the sump.
OK,
