Item Details
The Item:
I have a mobile Perkins 6.354 Power unit on a hitch-pin trailer. Built into the trailer is a 100 gallon fuel tank and a steel roof to cover the unit. I believe it was used to drive a water pump.
The Good:
New fuel lines.
The engine runs strong.
Good battery
Has in-line electric fuel solenoid to be sure the unit will shut off should something happen.
It is a convenient package.
Plenty of room to add a tool or supply box.
The Bad:
No hour meter
The gauges are useless.
I do not know if that is a clutch or PTO output but it has a shaft that appears to be cut off.
A very small leak where the engine oil drain hose bends to the opposite side of the unit.
The Ugly:
It is listed for sale locally for $4750 as is.
Looking for someone interested in the unit as a whole, but will consider separating the engine from the trailer.
For a fee:
The Good:
New fuel lines.
Good battery
The Bad:
No hour meter
The Ugly:
For a fee:
- I can change fuel filters
- I can change engine oil and filer
- I can flush and fill coolant.
- I can add new volt, oil pressure, temperature, hour and tachometer gauges. I supply a stick for a fuel gauge.
- I can repair exhaust.
- I can put a lid on the intake.
- I can paint the unit.
- May deliver.
