Fixing vintage Ariens Snow Throw bottom scraper
   / Fixing vintage Ariens Snow Throw bottom scraper #1
man114
I garbage picked this last year, 4hp early 1970s, bottom scraper broke off because of rust at the bottom of the assembly. Wondering what my option is here. It is solid other than at the very bottom where it is bolted. Maybe 1/2 inch up it is perfect. I could get a wider piece of metal and bolt it higher up. I do have access to a welder at work as well. I could get a slightly longer scraper and weld the bottom scraper to the side skids and in the not rusted parts. The snowblower itself is functional, I used it quite a bit last year.
   / Fixing vintage Ariens Snow Throw bottom scraper #2
You can probably find a used bucket as the motors or auger gearbox fail. I restored one but the bottom was OK.
I restored and repowered it.
2018 Honda CR-V LX SUV (A50324)
2018 Honda CR-V LX...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2013 Mack GU713 T/A Roll-Off Truck (A50323)
2013 Mack GU713...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
