Fixing used Rotary cutter blades
   / Fixing used Rotary cutter blades #1
BBerni
MF135 (1975)
Hi,
I own an old rotary cutters where the 4 blades are used. I want to load up the cutting hedge before sharpening but I not sure what rod type I should uses
Blades thickness == ½ in
Any suggestion?
Thanks a lot.
   / Fixing used Rotary cutter blades #2
Buy new blades! It's not worth the risk. The heat could damage the blades, and then they come apart.:eek: Just not worth it to me.
   / Fixing used Rotary cutter blades #3
What he said. If you've ever had one break or come loose, you'll not even consider welding on them.
   / Fixing used Rotary cutter blades #4
Yep. Like the others said replace them. Too easy to start a crack and have a piece get flung off at high speed. Could go through a car door, or the side of a house. Won't do your tires any good either.
   / Fixing used Rotary cutter blades #5
Definitely don't weld them.
Larger gouges/etc. can simply have the gouged edge sharpened, they will still cut just as well.
Past a certain point they need to be replaced. They are not that expensive and last a long time.
Got it!
Thanks
   / Fixing used Rotary cutter blades #7
Have to agree, don't weld them.
I run a couple batwings and large fixed deck mowers. as much NOT-FUN as it is to buy6 blades at a time.. it's better than welding one and have it fly out the side or back of the mower and thru a concrete wall and thru the occupant and thru another wall.. yada yada
I seen a blade shoot out go thru a 500$ tire and hit a tree in a field.. and that one wasn't welded. just freak acident!
   / Fixing used Rotary cutter blades #8
Hmm we have had a local welding shop build up the tips of our bushhog blades since 1969 and never had a problem . They add about 4"s where we have a longer wear period . The look like a one sided axle . It's cheaper for us to just have two sets of blades and have them retipped than buy new all the time . And we get long life out of the retipped blades on staying sharp . Not sure on the steel that's used but it stays sharper than new blades .
Sent from my iPhone 5 using TractorByNet
   / Fixing used Rotary cutter blades #9
i'm surprised they want the liability!
   / Fixing used Rotary cutter blades #10
Hmm we have had a local welding shop build up the tips of our bushhog blades since 1969 and never had a problem . They add about 4"s where we have a longer wear period . The look like a one sided axle . It's cheaper for us to just have two sets of blades and have them retipped than buy new all the time . And we get long life out of the retipped blades on staying sharp . Not sure on the steel that's used but it stays sharper than new blades . Sent from my iPhone 5 using TractorByNet
They weld a new piece on the ends? Does it wobble or shake?
2008 Ford F-450 4x4 Crew Cab CM Service Truck (A52377)
2008 Ford F-450...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
JLG 1255 Telehandler (A53472)
JLG 1255...
(2) 24" W X 5 1/2L HEAVY DUTY FOLD UP TRAILER RAMP (A51247)
(2) 24" W X 5 1/2L...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
A1 MIST SPRAYERS RESOURCES, IN TERMINATOR 60 R LOT IDENTIFIER 42 (A53084)
A1 MIST SPRAYERS...
