Fixing a road
   / Fixing a road #1
teg
Super Member
nowhere
s
This wasn't much work... The ditches got full and some water was running down the road instead of the ditches... This is the upper section.
   / Fixing a road
This is the lower section... just dressing up the ditch.
   / Fixing a road #4
Teg, did you grade it flat or put a crown on it? I can't tell by the pic's. My driveway is pretty steep, if I don't crown it the water just runs down the wheel tracks until it makes a gorge.
   / Fixing a road
Good eye :confused2: :) This section is on the list to be regraded once we move up there. There is a *very* slight crown and most of the water runs off except when the wheel "depressions" show back up.
When that happens I cut little side channels to help the water get into the ditches and use the dirt/gravel from the side channels to block the water from going down hill any farther.
   / Fixing a road #6
Yep, that's how I do mine. It is one of those thing that will always have to be done. My neighbors driveway is as steep as mine. He had it tar and chipped 6 years ago($35K) and now it is in need of repairs. Steep grades cause a host of problems as the years go by.
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
2001 Freightliner FL80 E-One Pumper Fire Truck (A52377)
2001 Freightliner...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2013 FORD F450 XL SUPER DUTY BUCKET TRUCK (A51406)
2013 FORD F450 XL...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A54814)
2012 Freightliner...
