Loader Fixed Problem with TC29DA raising 14LA Loader
   / Fixed Problem with TC29DA raising 14LA Loader #1
stoutga
Byron Center, MI
New Holland TC29DA
Hi All,
I am new to this forum but have visited for a year now and gained a lot of good information so I thought I would give back a little.
My NH TC29DA started having problems lifting my 14LA FEL. No problems with the bucket operation or going down. I had to pull back the joystick hard to raise the FEL arms at all but they were very slow. I had just changed the HYD fluid a few months back so thought I might of added a problem there. I read a lot online but didn't find an exact solution to my tractor/FEL.
Turns out I just had to open the rubber boot of the joystick and look inside. The joystick screws into a plate that has three allen head bolts and each connect beneath the plate to the valve. The Allen head screw that raised the FEL was very loose and that was causing this problem. Tightened it up and now I am back to full FEL operation.
Hope that helps someone.
Thanks to this site for all the great information.
Stoutga
   / Fixed Problem with TC29DA raising 14LA Loader #2
Hi. Welcome. Good reminder to check simple first.
   / Fixed Problem with TC29DA raising 14LA Loader #3
Thanks for the info! And welcome!
Chris
2003 Hummer H2 4x4 SUV (A56859)
2003 Hummer H2 4x4...
404 (A52706)
404 (A52706)
Hose Reel (A55787)
Hose Reel (A55787)
TANK MANIFOLD (A58214)
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
