Forks fixed or adjustable
   / fixed or adjustable #1
magicheater
Veteran Member
central Wisconsin
Kubota B7800, B26 TLB
Just wanted peoples opinions on their preference and why. I have adjustable forks on my 3PH and don't adjust them that often. A pallet jack is not adjustable and there are a bazillion of those around. Just curious.:anyone:
   / fixed or adjustable #2
I guess it depends on what you are lifting. I work in the Maintenance dept. at my work and we are adjusting the forks our lift truck all the time to pick stuff up. It depends on width of the object you are lifting.
   / fixed or adjustable #3
pallet jacks are made to pick up one thing: pallets. I'll bet I use my 3 point forks less than 25% of the time to pick up pallets. I also move my forks quite often.
   / fixed or adjustable #5
I would be lost if I could not adjust the width of my forks.
   / fixed or adjustable #6
Adjustable fixed forks not floating forks. Many more uses for these including moving stumps and odd shaped items. I should add sometimes you need them to be adjustable to initially palletize materials. Pallets are easy with fixed forks but most of us do all sorts of things with adjustable forks.
Mahindra 6065PST (A53317)
Mahindra 6065PST...
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A55852)
2019 Ram 1500...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
40' CONTAINER (A51244)
Deere 335P (A53317)
Deere 335P (A53317)
2016 MACK CXU613 MID-ROOF SLEEPER (INOPERABLE) (A55745)
2016 MACK CXU613...
