fix pto on ford jubilee
/ fix pto on ford jubilee #2
Welcome to TBN
Need a little better description of the problem. Does the engagement lever feel the same as in the past? Does it kick out of gear with nothing connected, with anything connected, just under heavy load? Have you checked the oil levels? Does the transmission feel the same?
/ fix pto on ford jubilee #3
The pto was proably jambed by some implement. There is a snap ring that holds the pto shaft bearing in place. The housing will get damaged and the snap ring will come off. It's a easy fix. Just make sure to "fish" out all the pieces that may be in the alxe housing.
/ fix pto on ford jubilee #4
yep.. could be bad snapring.. or just plain bad bearing.. if there is in / out movement on the pto shaft.. it will walk itself out of engagement.. and chey up the sliding splined collar int he process. fix this one sooner than later.
post back if you find any in / out or up/down play in the bearing/carrier.
soundguy
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused Fuel Heater (A61166)
New/Unused Fuel...
2020 Ford Transit 350HD Cargo Van (A61568)
2020 Ford Transit...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
2023 Caterpillar 289D3 Skid Steer (A64047)
2023 Caterpillar...
2002 Ford F-250 Service Truck, VIN # 1FTNF21L52EB33349 (A61165)
2002 Ford F-250...
