fix for sticky tilt stearing wheel on 4310
   / fix for sticky tilt stearing wheel on 4310 #1
chickenman
on the side of the plastic stearing wheel quadrant i drilled a 1 1/2" hole on either side and plugged them with faucet hole plugs.
now when i have the wheel sticking i remove the plugs and blow the dirt and dust out with an airhose.
one thing i learned is DONT USE OIL
i replaced the tilt mech myself
it is one sorry piece of engineering
i dont recomend that you pull yourself up by the stearing wheel or squirt oil into it.
   / fix for sticky tilt stearing wheel on 4310 #2
I have a new 4410 and have had the dealer replace parts in it (the tilt stering wheel) twice. It is a terrible design and JD should come up with a newly designed replacement for it. It's the only complaint I have with the machine but it's kinda central to using it don't ya think? /forums/images/graemlins/mad.gif
   / fix for sticky tilt stearing wheel on 4310 #3
I had never touched the tilt on my 4310 for the two years that I owned the tractor. When I read about the sticking problem here, I checked mine and it too was stuck. I sprayed it with WD40 and it has been fine ever since.
Richard
36in Digging Tooth Bucket Excavator Attachment (A56857)
36in Digging Tooth...
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
11L-15 TIRE W/ 6 LUG ALUMINUM RIM (A52708)
11L-15 TIRE W/ 6...
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 14ft...
2019 Freightliner M2 106 Flatbed Hauler Truck (A55973)
2019 Freightliner...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
