Fix for 62D MMM Creating Divots with Front Wheels
   / Fix for 62D MMM Creating Divots with Front Wheels #1
chevy
Platinum Member
East Central, Indiana
Kioti CK3510SE HST, John Deere X739
I believe I have come up with a fix for this problem.
I added grease zerks to the pivot points. The wheel bracket now spin very well on the shaft.
I also rounded off both the square edges of both wheels. I used a 1 1/2" radius router bit to round the wheels. It makes a mess. The dust that comes off the wheels is very fine.
I mowed tonight for the first time after making the fix & the wheels did not dig in one time. It raind today so I was not expecting it to work so well.
   / Fix for 62D MMM Creating Divots with Front Wheels #2
I was at a JD dealer a while ago, and mentioned the divot problem to a salesman that was showing me the 2000 series. He said that the wheels are designed to be locked in the forward position, and should not be free to rotate. He said that the JD decks are suspended, and the wheels should only act as anti scalp devices. He said that he has seen people running the decks with the lock for the wheels unlocked, and suspects that they will have problems.
In the real world, does he make sense at all?
There is no way to lock the front wheels on the 62D deck. They are made to swivel. He is correct in that the wheel are run suspended. The problem comes in when your lawn is not as flat as a football field.
   / Fix for 62D MMM Creating Divots with Front Wheels #4
Where is the pictures of the repair...:(
Chris...:)
   / Fix for 62D MMM Creating Divots with Front Wheels #5
The only lock is for height adjustment. The front wheels are made to rotate. I had the dealer enter a trouble request on mine and it came back to install washers (which act as a bearing surface) and grease fittings to allow the wheels to spin more freely (which the dealer complete)
   / Fix for 62D MMM Creating Divots with Front Wheels #6
I've operated all kinds of commercial mowing equipment and don't understand JD's theory on this one. The only deck wheels that should be designed to swivel are those on a non floating deck, where the weight of the deck is always on the wheels. I can imagine the way those caster wheels spin freely then "land" in a bad position when the terrain changes. I have not seen it as I have the 62c on a 2305 and it doesn't have any such problems.
Chris...:)
Sorry Chris,
I have been working to much. I was lucky to get the mod done & the yard mowed.
   / Fix for 62D MMM Creating Divots with Front Wheels #8
chevy said:
Sorry Chris,
Chevy , read my reply to the other thread about the problem. the wheel is not offset enough to work right. it was a design mistake. you need to brake out the plasma torch and welder. its a easy fix...:) Maybe i should get all of you to send your wheels to me for fixing. i could get rich. :D 3 inch offset. and it will never dig in the yard again....;)
Thanks Chris.
Now I feel like a moron. John Deere had the idea first.
I should have read more about the problem here.
   / Fix for 62D MMM Creating Divots with Front Wheels #10
My dealer is delivering my 2320 tomorrow morning. I'll get his opinion on this issue. The 62D is on order and I should get it in 10 days apparently.
Chris can you post a picture of your fix?
Gord
2007 FREIGHTLINER COLUMBIA 120 (A55745)
2007 FREIGHTLINER...
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
2013 BMW 528i (A55758)
11' Container (A53316)
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
