Dirt Moving First Workout for the MX5800
   / First Workout for the MX5800 #1
bdhsfz6
Elite Member
Northeastern Pennsylvania
Kubota MX5800 HST & L6060 HSTC Formerly L6060 HST B7100 HST, L2550, L3010 HST, L3430 HST
I put my year old MX5800 and BH92 hoe through it's first workout this week. I dug out a shale bank to level an area for a shooting range. I put 8 hours on the clock, mostly ripping red shale with the hoe, using 11 gallons of fuel in the process. I probably could have done it in much less time if I rented a bigger machine but I wanted to see how well the MX handled the task.
I was impressed with the power of the BH92. It did tend to move the tractor around a bit while ripping the tough stuff. I used a 12" bucket on the red shale and tree stumps but probably would have done better with a single tooth ripper. I had no mechanical issues and overall, I was very happy with the performance of the MX.
   / First Workout for the MX5800 #2
How do you like the manual thumb? I had the manual on my BX but got the hydro on my MX and it is my favorite thing next to my grapple:D
The manual thumb is a pain when you have to get on and off the tractor frequently to set it up. I use it mostly for picking rocks. For most other tasks, I also use the grapple. I may consider adding the hydro later if the need arises. Shouldn't cost much. Just hoses and a cylinder if I use one of the rear remotes to control it. Did you get the foot operated thumb control valve on your MX?
   / First Workout for the MX5800 #4
Figured as much, that's how I felt about about t on the BX.
I got the foot operated and I don't have any complaints.
   / First Workout for the MX5800 #5
You may think that but I looked up the price of just the cylinder last winter and it was nearly $700. I wound up buying a much less expensive cylinder and teeing into the bucket lines with a solenoid valve on the cylinder side line. I've got a push button on the joystick and when I push it both the thumb and cylinder get pressure, release it and only the bucket gets pressure. Got the idea from some threads here, I think I may have pictures of my setup on here somewhere also. I had to modify the thumb a little for fitting clearance and it doesn't tuck up as neatly as it would with an OEM cylinder, but it's a lot better than manually adjusting the thumb and a lot less expensive than the factory setup.
I saw a post from someone in another forum who used a $150 cylinder from Tractor Supply and some hose from Discount Hydraulics. He used one of his rear remotes. It's a stretch to reach the remote valve on the MX from the BH seat though. I like your idea better. He claimed the whole project cost under $300. That was a couple of years ago so the price may be up some now. Even so, it will be far cheaper than what Kubota gets for the OEM hydro option.
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2005 Chevrolet 3500 (A50120)
2005 Chevrolet...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50322)
2020 Kubota Z723KH...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
2020 Caterpillar 420F2 4x4 Loader Backhoe (A50322)
2020 Caterpillar...
2011 Cadillac SRX Luxury SUV (A50324)
2011 Cadillac SRX...
