First use on my new 1025R
   / First use on my new 1025R #1
cperky
Middle TN
John Deere 1025r with 120r front end loader, Hustler zero turn mower
My new tractor has 2.5 hours on the clock now. .2 when I brought it home. I took the loader off easy Peasy! Mowed the lawn. Great improvement as far as comfort compared to my older 42 inch hustler ZT. Also so much better on the slopes I have been dealing with. I felt much more comfortable and in control while mowing. I didn’t bypass the push to reverse function yet and it wasn’t to bad. I may still use the zip tie on the switch method , but wanted to try it first. I mowed a bit with the ROPS up then lowed them. Much better with them down as I went under overhanging limbs. I was quite pleased with the turning radius on the tractor. It doesn’t compare to a ZT but it’s one of the many features that sold me on the Deere even though it cost a little more than other brands. I did take the deck off and re installed it. It was a bit of a pain the first time. I think it will get better with practice. When re installing the loader about 3 hours after removing all went well except the black hydraulic line. I couldn’t get it pushed in. All others went on easy. When removing loader I made sure to let the pressure off the lines. I think the black one was in the sun and built up pressure. I resorted to a light tap with a hammer on the end of the line to relieve pressure. It went on fine after that.
All in all , after my first day I’m pleased with my purchase! I feel like I chose the correct size and features for my needs. Next test will be some loader work!
   / First use on my new 1025R #2
Better to loosen it rather than damage the plunger
I’ll give that a try if it happens again. Didn’t think of loosening it. Appreciate the input!
   / First use on my new 1025R #4
They make a special tool for that. I just take mine off inside.
A tool for loosening the line , or for relieving pressure? Any idea what the tool is called?
   / First use on my new 1025R #9
I still use the word xerox for a copy, I’m not promoting a company, just using it as a generic term. I guess I could start using “the internet search engine of your choice being gender neutral of course”. Maybe that’s more politically correct.
   / First use on my new 1025R #10
Ha!
I use Kleenex for tissue and Band-Aid for bandages.
MoKelly
IRMC High-End Massage Chair (A57149)
IRMC High-End...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
Giyi Mini Auger (A57149)
Giyi Mini Auger...
2015 DRAGON 130 BBL VACUUM TRAILER (A58214)
2015 DRAGON 130...
2016 DODGE RAM 3500 FLATBED (A58214)
2016 DODGE RAM...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2007 FREIGHTLINER...
