First tractor
   / First tractor #1
Pete.Mitchell
Branson 2515h
Greetings! I’ve been perusing this forum for the past few months as a guest and finally decided to create an account and dive right in.
First things first. I’ve never owned a tractor before
I’ve been reading and reading on what type of machine would be most suitable for my family
We are looking for something to help us with developing and maintaining 20 acres homestead
primary uses would be post hole digging, light road cutting, garden prep, pallet lifting of up to roughly 36” high to load onto my trailer, ground cleanup, building dirt bike trails and jumps, etc.
so id likely mostly use a loader, forks, backhoe, rake, blade, post hole (and maybe a tiller if it’s capable of doing such)
It seems I’ve cornered myself into two options.
the heaviest/largest 25hp tractor I can find OR a higher HP pre emission tractor. I have absolutely zero interest in owning a machine with modern diesel emissions. I understand that more power may help me work quicker. But I’m not a commercial operation seeking to maximize revenue. I have time. I think I’d rather be a bit under powered than undersized
I thought I had my mind set on the Kubota L2501 HST but I also sometimes do a bit of analysis paralysis and fortunately that let me to a handful of other options (initially I thought it was only the kubota vs the JD 3025)
it appears that the Kioti CK2610 might in fact be a bit larger/heavier than the Kubota with a larger hydraulic and lift capacity. The motor appears to be a larger detuned one as well. I’ve seen some talk about being able to open them up a bit to reach 33hp (I’m a gear head haha). I also like the location of the loader controls compared to the more forward controls of the Kubota.
we have both a Kubota and a kioti dealer within 40 miles of us. Not much else within that radius.
I don’t intend to make this a kioti vs Kubota thread. Just trying to provide as much info as I can.
am I being unrealistic in the expectations of a 25hp tractor on 20 acres? The land is flat.
I’m not against a larger pre-emission tractor. I just hesitate on that as I don’t really know what to look for and don’t want to buy a junker
Any insight or advice would be greatly appreciated!
   / First tractor #2
On flat land, I believe the 25HP tractor can get the job done. It may be a little undersized on 20 acres but, that just means it’ll take you a little longer to accomplish your tasks.
I have a Kubota L2501 HST and highly recommend it for its simplicity, reliability and performance.
That said, you can’t go wrong with the Kioti and/or the JD or a whole host of other comparatively sized 25HP tractor options.
Mike
   / First tractor #3
I bought a 34 HP tractor as my first and it was adequate for most of what I needed for maintaining 40 acres (20 rolling pasture, 20 wooded trails). I often ran into situations where it was too small (more accurately, too light) for some tasks. After 27 years I replaced it with a 45 HP last spring and wish I had done so many years ago. Not so much for the HP, but for the size and weight. You've probably already seen the posts regarding weight as being high on the list of considerations. Good advice there.
Welcome to the forum and good luck!
   / First tractor #4
An L2501 or the newer L2502 (or Kioti 2610, Deere 3025E or D) would be fine for your application IMO. When I acquired adjoining property I changed from a Kubota B2650 to the L2501 and it did everything I needed which is about what you are interested in, other than I didn't buy a hoe for it. I just wasn't sure I'd have enough use for it given the rather large amount of money spent.
   / First tractor
Yeah I’m on the fence about the hoe as well. Seems my money could be spent on other implements but I still go back and forth.
Side note: I just discovered that the bobcat CT2025 is essentially a rebadged CK so that at least expands my options of inventory a bit more. Apparently the Kubotas are months out right now locally.
I do think I’ll be content with a 25hp unit, I’ve just struggled to determine if the L2501 and CK2610 are in fact the heaviest of the 25hp options.
   / First tractor #6
Good luck in your search. Try to not over think this. Start visiting dealer lots looking at everything they have in your size preference, new and used. Just sitting on a tractor can tell you more than all of us can. And being inexperienced I recommend operating any tractor before buying it. Depending on your dealers, they may let you take one home for a day.
   / First tractor #7
Kioti all day long. Wouldn't even consider the Kubota. Only tractor I'd consider over the Kioti is the Mahindra 1626 because it Japan built and in my opinion, has a much better backhoe mounting setup.
Don't get me wrong, I'm not anti Kubota, I just don't think you get much for your money in these smaller machines.
John Deere is a definite no for me. I'm not interested in a tractor with an aluminum rear axle housing and plastic body panels, their seats have always been junk. Not to mention their business practices in general.
The Kubota and John Deere don't offer shuttle shift either.
By the way, I have 28 acres and not not all flat. Not at all.
   / First tractor #8
FWIW, in my case, I bought my 25 acres spread 42 years ago. It's 10 acres of woodland and the rest former pasture & groomed lawn. My first tractor was a Kubota B7100 HST with FEL and backhoe. I used that little 19 HP machine for over 20 years doing all that needed to be done including the excavation for my house & barn.
In 1998, due to an adjacent property owner dispute, I was forced to assume the maintenance of a 1.25 mile private road leading to my acreage. Although the little B7100 was able to do most of the work, it was pitifully slow. Since then, I've moved up to a 25, 30, 34 and now a 60 HP tractor. The larger machine is much faster at doing the same work and a lot more comfortable on these old bones.
My point is, if you have the time, a 25HP tractor will do all the work you describe. At some point, you may decide your time is more valuable. If that happens, you can always trade up like I did. If you take care of your equipment, it will hold a good deal of it's value.
Other than the distance to the nearest dealer, I don't think the brand of tractor you choose is all that important. Parts & service availability both now and in the future are the biggest concerns. It seems many dealers today change brands as often as I change my socks. :)
Welcome to the forum and good luck with your choice!
   / First tractor #9
Welcome to TBN Pete.
Not sure if you live in snow region,if you do may want to consider winter task.
Visit dealer see if they let you take test spin models 30-40 hp.
   / First tractor #10
My tractor is the first and only one I will own. Not knowing much about tractors when I bought, and learning as I go, I have learned several facts about buying a first tractor.
1. DO NOT get a tractor that is too small for what you want to do.
2. Whatever you want on the tractor (remotes etc), it is best to get it when you purchase your tractor from the dealer.
3. Buy any brand YOU like, regardless of color. You are the one that has to live with your choice.
4. Weight matters. Make sure it is heavy enough to do what you want. CONSIDER ballast in the tires from the beginning.
5. Get a tractor with tires that match your intended use.
6. If you want implements, try to make some of them part of a package deal from the dealer when you buy the tractor. Usually cheaper.
7. I also believe, if you don't like the dealer, you probably soon won't like the tractor.
8. Remember, a tractor is like a computer. When someone asks What are you going to do with it" you may give them one answer, but it will need to do any task you come up with. Example - I use our tractor to lift the roof trusses to the top when I built the tractor shed.
I like to feel like my tractor is like my dog, one of my best friends. Best Wishes.
OH almost forgot, WELCOME to TBN.
2015 FORD F-150 (A50854)
2015 FORD F-150...
CHALLENGER VACUUM PUMPS (3) (A50854)
CHALLENGER VACUUM...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A51039)
2016 KBH...
Lift Station Pumps (A49461)
Lift Station Pumps...
2017 SANY SY365C LC EXCAVATOR (A51242)
2017 SANY SY365C...
