LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,136
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
For the op, the service facility is more important than a lower price. We have most brands within 25 miles of home. Did some online research, was ignored at the JD dealer, Mahindra and LS/Boomer not in the running. Kubota likes their orange paint a lot, seemed like they wanted to keep the tractor. Massey was my choice, ten minutes of sitting in my 1742 cab model. Didn't run or drive it, just felt right. Previous land owner dealt with them lots, good enough for me. Had a starting issue, started better not plugged in when cold, called the sales guy, he hade the service come out to check in a couple of days. Of course it didn't act up then. he did a scan, no fault codes, said problem is documented, keep in touch if it occurs again. Have 118 hrs on it so far.
I don't know on your model, but on my tractor when plugged in an warmed up the manifold heater is controlled by a temperature sensor. If the water jacket is warm it thinks the tractor and air is warm and doesn't run the heater. When you crank it over that's cold air coming in which will not start well, I turn the key on and off several times in cold weather when plugged in, I'm thinking about getting another sensor and mounting it in an ambient air location.
