Buying Advice First tractor- Could really use input
   / First tractor- Could really use input
Well I went today and made my decision and was pretty surprised at what I decided. I actually went with the BX25D with 48"bush hog, added a thumb to the BH, and grapple with third function. I just decided since I was the one that would be using it all the time and my 10 and 11 year old daughters I felt most comfortable with its removing and booking up implements, etc. I figure if I need something bigger done that it can't handle I probably need to hire a professional to do it. I can hire a bunch of professionals for the extra 8-10K that the L2501 would cost me equally equipped. They have to order the grapple in and get it installed and then it should be ready sometime early next week if not sooner.
   / First tractor- Could really use input #82
Congrats on the new tractor! I think you will love the BX. I have a similar sized tractor in a different maker. I can do anything with it that you mentioned wanting to do. Grapple will be very nice. One bit of advice is to perhaps to pick up the cheapest dirt scoop you can buy on Craigs List... rusty and crusty is ok. Reason being they make great ballast and they make a great way to carry tools (i.e. tools, shovels etc.) to wherever your working. 14 acres is pretty large and you may want the extra tools with you. When ever you are doing dirt carrying or grapple work have the dirt scoop on. It will help with ballast and traction. Also, have someone who has had a tractor with a loader for years show you do's and don'ts.. I think every tractor newbie should do this..
One tip I would advise all newbies is.... Don't lift your bucket full of material higher than you need to and certainly don't make sharp turns with the bucket raised high and full.. you could flip the tractor.
Enjoy the new rig and post pics!
   / First tractor- Could really use input #83
Congrats! Never a bad choice if you've thought it out, and you're happy with it.
   / First tractor- Could really use input #84
Enjoy! Be safe. ROPS and SEAT BELT. No one rides with you in the bucket and keep the bucket low.
   / First tractor- Could really use input #87
Congrats on the new BX! :thumbsup:
As far a ballast goes the metal fabricated boxes can be expensive. Fortunately when I bought my tractor the guy had a Kubota box which was included so I haven't personally fabricated one. There are lots of alternatives to making your own. Most are concrete and people have used all sorts of forms/barrels to make one. Here's a link with an example of a DIY ballast...http://www.tractorbynet.com/forums/build-yourself/203605-poured-concrete-ballast-box-build.html
   / First tractor- Could really use input #88
Yes, safety first. Does the BX25D have draft control on the 3pt? If so, be SURE to completely turn off before mounting a 3 point backhoe.
rScotty
   / First tractor- Could really use input #89
Thank you for the feedback. I have actually talked my husband into the backhoe attachment but after reading your post I am wondering If I shouldn't spend the extra money. What are your thoughts? We have beavers that like to increase our dam size and thought it would be useful every time they do that to break it back down and I am currently clearing out a lot of tree growth along fence lines and some cross fencing that I thought it would be helpful with removing as we work on it.
Growing up on a farm, we never had tractors with FEL's or backhoes. Now both my tractors have FELs and my go to tractor is my little B26 TLB. You never run out of uses for a small backhoe. Removing beaver dams is just on of them. I haven't use my wheelbarrow since getting my FEL tractors and rarely use a shovel except for final digging around delicate things like water lines etc. I plant trees and shrubs using the backhoe to dig the holes.
AS for a mid mount mower, I think if you consider the cost of a MMM vs a dedicated ZTR mower, you might spend another $1000 to get a very good ZTR high end residential mower and you wont be sorry for spending the extra money. A good high end (almost commercial grade) ZTR will run around $5500 new. I think you will find that a MMM will be around $4K or more and some of them would require removal to work the 3 PH or work in the woods without damaging them.
I am a firm believer in getting the right equipment for the job and mowing a lawn is not the best use of a tractor in most instances especially when larger acreages are concerned. If you just had a couple acres of manicured lawn and wanted a tractor (think BX25) so you could use the FEL for hauling mulch, back hoe to dig a small bit and a MMM to mow the large area, then great, but you would still need a push mower to finish up around trees and likely next to buildings that is unless you want to be repairing the accidental brush against the building with the tractor.
Do some $$$ comparisons between the use of MMM and dedicated mower and you may find that you can swing the extra payment for the ZTR or even a lawn tractor. My brother in law has used a Craftsman 6500 series lawn tractor for 7 years and over 800 hours and still going strong. I think it cost about $2500 when new.
   / First tractor- Could really use input #90
Gary,
IMHO, A small TLB like the B26 with a mounted backhoe and an accessory 3 point hitch is a whole different machine from a BX25 tractor that has a mounted 3 point hitch and an accessory backhoe. The TLB is more usable, safer, and more stable. I've had both. Would you agree?
rScotty
FORD COBRA REPLICA RACING CAR (A51222)
FORD COBRA REPLICA...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
2023 KAWASAKI MULE (A51243)
2023 KAWASAKI MULE...
2011 Nissan Rogue SUV (A50324)
2011 Nissan Rogue...
