Mid-Mount Mower First time use of MMM deck (Kubota b series)
   / First time use of MMM deck (Kubota b series) #1
maciek8791
Yanmar
Hello, I am an owner of b-series kubota tractor since one year. Before I was always using a 3point hitch mower with a bucket to collect the grass. I decided to try also MM mower because I found very good price opportunity. It has been installed and after first cut, I have some mixed feelings. The grass was not so much high, but the entire field is covered in grass leftovers - I have rear (not side) discharge version. My plan is to wait now until the cutted grass will decompose and then I want to try to cut it with MM BEFORE it will grow - like once or maximum twice per week. I have a question : if You are working with MMM like I plan to do it, so with not so high grass, do You get this effect of not seeing any grass leftovers? Strategy is to use it like a mower-robot, which custs just the top of the grass. Becuase if there will be a mess, I will most likely return to the old mower. However the one on the 3-point hitch is only 120cm and MMM is 150cm - I can really feel the difference. I do not have to dispose the cutted grass as well and finally - cutting the edges is a different world. I wonder what are Your thoughts on this topic?
   / First time use of MMM deck (Kubota b series) #2
what rpm you cutting at?
   / First time use of MMM deck (Kubota b series) #3
Are mowing grass when it's dry?
Try mowing 2/3 or little less of deck width.
   / First time use of MMM deck (Kubota b series) #4
I cut with a mmm but have a mulch kit, which helps. Unless mine is really long, I don’t see a lot of cut grass afterwards.
   / First time use of MMM deck (Kubota b series) #5
How tall was the grass you were cutting?
The MMM brand new with sharp blades (and facing the right direction)?
Kubota L4701 (A53317)
2016 FREIGHTLINER CORONADO 122 SD DAYCAB (A55745)
2016 FREIGHTLINER...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A55851)
2025 84in Dual...
2011 CHEVROLET SILVERADO 1500 (A55745)
2011 CHEVROLET...
1999 Southwind Fleetwood 34N 34ft Class A Motorhome (A55853)
1999 Southwind...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
