First time tractor buyer for haying
   / First time tractor buyer for haying #11
I have worked in central NY with winter temps down to twenty plus below 0, Many a green farmer with 20 through 40 series that owned a red tractor for the manure spreader because as they would say "they start better unplugged then the green ones plugged in!
Watch the 30 series, they had the same rear end as he 20 series and with the added weight they did have an update to the 40 series as they had a lot of failures within the first few years.
I hadn't heard any farmer who disliked the two pto's on the back of the red tractors, beat having the oil running out because of not backing up step enough of a slope to have the oil running out the back when changing shafts from 1000 to 540 or vise-versa.
The torque amplifiers when used properly would last 7,000-8,000 hours and longer. When used as a brake for the tractor to slow down they normally ran about 2,500 hours before failure. Many failures happened because of lack of knowledge of proper adjustments as well as the charge pump to the system got weak and kept driving and using the tractor because it still worked some!
I don't know where other then you are more familier with the deere line that they are easier to work on? Pto job on red, four hours, deere split it! Brake job on red four hours, deere split it!
Watch out for those that just had new pumps put in but not a brake job! Older deere's only filters the return not the pick-up on the oil so the first sign of the brake failure is actually the hydraulic pump failure!
Kinda hard to tell what brand is close to Art's heart, not?
Actually, pretty much everything he posted is very close to the mark.
The other reason IH tractors were on the manure spreader is because they only had to be driven a half-hour per day! (just kidding, Art!)
   / First time tractor buyer for haying #13
I myself cannot offer any opinion on this size machine, but here is hopefully some help.
One of the smartest gents' that I know; witnessed him repair everything thing from diesel engines, transmissions, electrical motors, cnc machinery, pneumatic logic circuits, etc., purchases anything he buys based upon it's construction and expected service life. He bought a new tractor for his large row-crop farm in the late 70's. The tractor was a IH 1066. It is still is service, albeit with minimal useage, but without any work other than a few minor repairs and typical maintenance.
   / First time tractor buyer for haying #14
Thank you!!
I should have spelled out the easier to maintain part. Parts seem to be easier to get, and basic service is very simple. Not that IH is that much harder, but if you have to wait for parts it takes longer. I think this is only going to get worse for CNH due to they have David Brown, Case, Farmall, IH, CaseIH, Steiger, Ford, NH, etc. All of these lines under 1 company now, dealers can't stock them all all of the time.
The stack shaft I said "I didn't like", meaning my opinion. I didn't like it due to you already have the PTO at an angle and it just seemed like when I turned with a 540 impliment the drive line would chatter or vibrate more than with any tractor I used that the shafts lined up correctly.
   / First time tractor buyer for haying #15
I go to YTM and Red Power, (I also have freinds with 66 series tractors). This comes up a lot over on these sites. Seems to be a lot of people with IH think the TA's were a weak spot on the old IH's in tillage and other high HP applications they seemed to have a bad rep.
If this is from lack of knowledge (I double all of it is) then this goes back to IH not getting the information out.
   / First time tractor buyer for haying #16
One more note on tractors be it Deere or IH. This is my opinion but for haying I would stay away from any with a powered front axle. This in the age tractor you are looking at.
Deere used what they called Front Wheel Assist. As long as you used it as an assist it worked OK. By that I mean if you only used it in the spots in the field you needed it and left it off the rest of the time, I had good luck with it. If you used it like a true MFWD, the oil would heat up and the system would have so much slip it wouldn't work. Basically it would pull you deep into mud hole and on the other side the wheels when they hit solid ground would not spin enough to pull you out. Good in theory and works on road graders, combines etc. Not very good on a tractor. These were on 20-40 series Deeres.
IH used at least 2 and I think 3 different axle suppliers, Elwood and Coleman, maybe one other. One system didn't use planetary gears, but a direct drive system. I used one once that the owner told me if I forgot to turn it off and back up, or drove very far down the road with it on it would snap the drive shaft. The 2nd did use planetary axle, from what I have read and again one owners own experience it wasn't very durable. The last system is very similar to what is used today. This system is suppose to be the best, but turning wasn't very good. These systems were on 06, 56, and 66 series tractors as a add on system.
I have driven IH with all 3 axles and if you need it, there better than not having (and better than Deeres), but if you don't not worth it IMO.
Again, just my $.02 on it.
   / First time tractor buyer for haying #17
I would go with the deere and my advice is get a cab you won't regret it and if you're doing round bales get a loader it's a must.
   / First time tractor buyer for haying #18
On front drives starting with the deere, it was hydraulic and the best thing to do was work with it off!! Then when you got into trouble turn it on and get out of your trouble!!!!
Other wise it just got you into more trouble!!!
The original IH was a coleman and it was great for straight lines and big fields as at the time it only ran about a 30 degree turn! Today many fronts are hitting up to 55 degree turns with the fronts. Elwood was an add-on till the 88 series and then they used it from the factory on some models. They also built some for deeres as well but they were not installer freindly do to the design of the tractor. The larger red ones last used spicer fronts. It is not unusual to find different front ends under tractors depending on the size required. The first mass produced four wheel drive tractor was actually a Same and europe was where they hit in first and all manufacturers have moved from make to the other through the years.
Any tractor no matter what color that has to be backed up or turning the wheels to disengage the front axle has either had tires that are the wrong diameter installed or they need the air adjusted to balance them from front to rear. We get to see this when hours are up into the 10,000 hour plus range from brand switching of the tires do to price or availability. Not the right way to do it but it sure has been done enough!
We have listened through the years to some of the manufacturers spread talk about the lack of parts because of the mergers. We haven't seen any problems with parts availability any more then any other color of tractor. It seems that after about twenty years they all bar none will discontinue slow moving parts!
Truth of it is a dealer that has sold the tractors normally has the parts in stock or they should!!
We get people asking us for parts of makes we don't sell on a regular basis because we are known in the area for our inventory of parts. Are prices are right and even having a big manufacturers wharehouse close by we still were able to get many people going when there dealer couldn't and they often found the parts at far better pricing!!!!
well i made my decision and went with a 1066 and a new new holland 5060 baler
thank you all for your input --it was very helpful and help me alot with my decision
SUNUP
   / First time tractor buyer for haying #20
Good info here... Most of my early years working tractors has been on red ones. But, I'm one of those that never really understood the T/A, either. Other than: "don't use it - 'cause it don't work right"! :confused:
I'm still feeling my way around with my hay making operation, too. I'd like to get my hands on a good 70hp @ pto tractor that doesn't tip the scales at 10,000lbs.
Been looking at the 2640 Deere with Hi-Lo and synchro tranny.
art's comment regarding the hydraulics and the brakes on the early JD's perked my ears up... :eek:
'Course that didn't make any more sense to me than the T/A confusion... whatya mean "bad brakes is a first sign that the hydraulic pump is going south"???
AKfish
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
(12) TOPPING JARS (A58374)
(12) TOPPING JARS...
(2) METAL DOORS & STAINLESS STEEL SHEET METAL (A58374)
(2) METAL DOORS &...
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A57453)
2003 Isuzu NPR-HD...
2008 HINO 26FT NON CDL BOX TRUCK (A59575)
2008 HINO 26FT NON...
2020 TAKEUCHI TB260 EXCAVATOR (A52709)
2020 TAKEUCHI...
