First time real tractor owner of a Kubota B8200D with BF300 loader.
   / First time real tractor owner of a Kubota B8200D with BF300 loader. #1
modaddysdotcom
ypsilanti
Kubota B8200D
I purchased for $4500 a used working Kubota B8200D with BF300 loader today as a project tractor to learn on. Any words of wisdom or technical assistance on what to do to bring it to peak operating would be much appreciated. I have owned and worked on cars and diesel trucks for 40 years but I am very excited to finally have tractor other than my trusty Sears GT. Normally I change all of the fluids in a new purchase but I have no clue what this tractor takes. That would be a good start as my loader operates quite slowly and probably needs a transfusion.
   / First time real tractor owner of a Kubota B8200D with BF300 loader. #2
best bet would be to go to the Kubota page and ask, welcome aboard
   / First time real tractor owner of a Kubota B8200D with BF300 loader. #3
Greeting Brian, There is a huge Kubota presence on TBN. You'll get a better response to your question in the Kubota forum. Welcome to TBN. Post some pictures of your tractor too.:thumbsup:
   / First time real tractor owner of a Kubota B8200D with BF300 loader. #4
Welcome from Oklahoma.
Ken
   / First time real tractor owner of a Kubota B8200D with BF300 loader. #5
Welcome to the forum.
   / First time real tractor owner of a Kubota B8200D with BF300 loader. #6
It would be in your best interest to obtain an Operator's Manual for your make and model. Welcome aboard. Best wishes.
   / First time real tractor owner of a Kubota B8200D with BF300 loader. #8
Welcome to TBN :)
I moved your thread to the Kubota Owning/Operating forum.
   / First time real tractor owner of a Kubota B8200D with BF300 loader. #9
If you are really serious about working on it and keeping it for a number of years, the very first thing you should do is obtain ALL the manuals (Operator, Service, and Parts) that you can. Some can be found online, usually, for what might seem to be a little expensive, but well worth every penny when you need it. Well worth it to have when you get the urge to get into it and see/repair something you're not sure about.
Good Luck
Ron
   / First time real tractor owner of a Kubota B8200D with BF300 loader. #10
I had a B8200HSTD for 12 years or so. GREAT tractor; built like a tank, albeit a tad under-powered.
Get the owners manual. It will tell you all the filters and fluids. I would change them all on a used machine. Dont forget the strainer under the banjo fitting below the right side foot rest. A lot of the filters are available from NAPA.
Make sure to grease all the zerks. Be sure to get the one on the range lever; it is hard to see, but is there. And, get the ones on the clutch and brake rod tubes, under the tractor.
Putting the oil dipstick back in the engine is tricky because it is hard to see. Usually can see it by looking from the side, not from above.
The manuals are still available; owners manual is around $20. It lists all the filters and fluids. also shows all the grease zerks.
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
2016 CATERPILLAR 239D SKID STEER (A51242)
2016 CATERPILLAR...
12in Backhoe Bucket (A52128)
12in Backhoe...
TRAILER AXLE (A51244)
2020 CATERPILLAR 279D3 SKID STEER (A51242)
2020 CATERPILLAR...
2012 Ford Escape SUV (A50324)
2012 Ford Escape...
