Loader First time putting a loader back on.
   / First time putting a loader back on. #11
This is a learning curve like the guys above stated. When you park the tractor with the intention of removing the loader, turn the tractor off and rotate the joystick through each position at least twice to insure all pressure has been relieved before you take the hoses off. The hoses will pop off under pressure but you have no chance of getting them back on under pressure. I didn't do this the first time and when I finally got the loader back on it was there to stay for a while plus I had hydraulic fluid all over the place! Now I take it on and off in five minutes or less. Just like any other implement, they all have a sweet spot. Some guys use a big hammer and some guys slow down and find the sweet spots. It will pay you big dividends on your equipment to find the sweet spots whether they are mechanical or hydraulic. At this point you need to take the pressure off of your lines. If you can't push the detents in on the quick connects with your finger then chances are they are pressured up. You have got to relieve this pressure in order to reconnect. Initially you have got yourself a super shooter so it goes in a rag or all over the place. For that reason, cracking a fitting on the line is a more controlled situation. Either way is not that complicated and you will be pleasantly surprised to discover how easy they go on and off. Every once in a while I get in a hurry and forget to do this until it is too late! Don't feel bad it's just part of the joy of having a fine machine.
   / First time putting a loader back on. #12
Bet the brochure told you how EASY and FAST it was! I had problems with our JD 640 loader as well, although never with the hydraulics providing of course you relieve the pressure..
Flat faced connectors I am told are supposed to be able to be connected and disconnected under pressure, but I think that has got to be at the top of the list, for the worlds greatest lies!
   / First time putting a loader back on. #13
Dont feel alone, Ive done it too. Just get something to press and release the line pressure on the FEL and you will be back in business.
   / First time putting a loader back on. #14
Yep! I can never get my grapple hydraulics to reattach after taking it off, no matter the conditions. I created a simple tool with a male and female flat face coupler and a couple pieces of pipe just to relieve pressure so I can reattach. The pipe is open so it relieves pressure without spraying everywhere like the hammer trick. BTW, I recommend a wood mallet over a hammer so you don't damage the fitting. But wrap it in a rag first, and keep hands and body parts back to avoid potential injury.
   / First time putting a loader back on. #15
Or, if you're more patient than I am, you can wait for a colder day ;)
Sean
   / First time putting a loader back on. #16
I've got flat faced connectors. That is truly a lie!!! :)
   / First time putting a loader back on. #17
What we REALLY need to do is launch a search for any owner of a 'quick connect' FEL that has NOT had a face fuel of hydraulic fluid! Happens to everybody at some point. :licking:
   / First time putting a loader back on. #18
Just relieving pressure does not always work because the oil may be warmer when you reconnect. You may disconnect on a cool morning or relatively cool day and reconnect several days or weeks later when the ambient temperature is higher. That happened to me and I had to resort to using a hammer to relieve the pressure. I got sprayed with oil because I did not put a rag over the connector.
A tip from one of the experienced TBN members has worked well ever since. That is, drain about 1 teaspoon of oil from each connector when you disconnect, leaving room for expansion.
Edit: here is the link to the previous discussion:
http://www.tractorbynet.com/forums/hydraulics/245727-options-dealing-pressure-build-up.html
In post #9 CJONE gives the tip about bleeding some fluid. SPYDERLK says the same thing in his posts.
2009 Chevrolet Cobalt Sedan (A55758)
2009 Chevrolet...
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
John Deere 853 20ft Corn Head (A55315)
John Deere 853...
2018 Cadillac Armbruster 70IN Limo - 43,279 Miles, Professional Coachwork, Clean Executive Vehicle (A55315)
2018 Cadillac...
UNUSED JCT 72" HYD TILLER (A57193)
UNUSED JCT 72" HYD...
76" SKID STEER QUICK ATTACH BUCKET (A57192)
76" SKID STEER...
