First time in snow with CK35
   / First time in snow with CK35 #1
tommaple
Summit County, Ohio
Kioti CK35, John Deere 625i Gator, John Deere 530, Allis Chalmers Model B
We had our first significant snow last night, 11" of lake effect snow that was soft underneath from the ground's warmth. I don't have a snowplow for the Kioti but I needed to move it to get out the tractor that does have a plow.
I have read the posts about starting tractors in the winter and wasn't sure what to expect. It went down below 20 degrees last night so I turned the key until the glowplug light went out and engaged the starter. I don't think it turned over a full revolution before it was running! I did keep the glow plug light on after it started (as mentioned in another post) and it did run smoother, with less smoke.
While it was running I thought I'd see how it behaved in the snow. The tractor has a FEL and R4 tires (unloaded). I've never had a tractor with these tires and was expecting quite a bit of slipping according to other posts I've read. I was pleasantly surprised. I dropped the loader, put it in float and drove up the hill from the barn. With the wet snow the loader was pushing a section of snow that extended 8' in front of the bucket. The tractor never missed a beat. It worked so well I cleared the majority of the drive with it. I would expect it to work even better if it had an actual snowplow that would cast the snow to the side.
I pass this along in the event it might help someone in their decision on tires and equipment for winter use. So far I am very impressed with how this tractor starts in the cold and operates in the snow.
The only remaining question I have will be how it runs in the woods with snow on top of soft, muddy ground. That may be where the lack of Ag tires will be most evident.
A happy Kioti owner.
   / First time in snow with CK35 #2
Glad to hear it went well with your snow clearing. :thumbsup: I have the same tractor and the first year I had it we had an unusual amount of snow, over 5 feet and I cleared our private road that is over 1/2 mile plus our driveway and are our building area, no problems. Had my backhoe on so got good weight on the back. Snow pics from 2 winters ago, the shiney tractor one is when I first got it 2 1/2 years ago. :)
Mousefield,
That's a pretty spot you have there.
These little tractors can do some real work! The FEL can't be beat for moving piles of snow.
Tom
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
LAND OF HONOR HAY GRAPPLE SKID STEER ATTACHMENT (A58214)
LAND OF HONOR HAY...
CAT Chassis Only (A59076)
CAT Chassis Only...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2020 DRAGON ESP...
2015 DRAGON 130BBL VACUUM TRAILER (A58214)
2015 DRAGON 130BBL...
