First TBN Power Trac Owner
   / First TBN Power Trac Owner
I pretty much run it at full throttle all the time when doing just about everything. I find the hydraulics are most responsive when the throttle is up. I've found that most of my time is spent doing loader work. I need the power to push into the material, to lift and to run it to where I'm going. The tractor doesn't seem to mind. /forums/images/graemlins/wink.gif
   / First TBN Power Trac Owner #12
It is true, my name was WillingtonPizza before I bought my PT and after I felt like I needed to change my name to a more PT friendly name. Even though I do not write much on TBN I do check it at least every other day.
Good to hear from you! /forums/images/graemlins/laugh.gif
   / First TBN Power Trac Owner #14
Does anyone know what's happened with Hans? He used to be such a regular contributor to this site and just seemed to disappear. I checked his activity the other day and he has posted just once since May. I know some people either get too busy, tire of seeing the same questions posed by newcomers or, occassionally, get their feathers ruffled over something. Just wondering.
   / First TBN Power Trac Owner #15
Yo don't think I ran him off do you... /forums/images/graemlins/blush.gif
   / First TBN Power Trac Owner #16
Hans is alive and well, but far too busy. I think he's praying for the return of the drought.
I don't think he's tested it yet, but he has modified one of the acrease wing mowers to go on the front of his PT425. That way there is a separate motor just to run the blades, and no drain on wheel power on hills.
And the man who did the conversion put shafts and a seat on it and towed it around his Pennsylvania shop with his road horse. Took a while for the horse to get used to the noise from back there. /forums/images/graemlins/laugh.gif
Yeah, Hans has mentioned that he actually uses his PT to make a living and only posts when he has time. Unlike us, who seem to have plenty of time to post. Hmmm, I better get back to work! /forums/images/graemlins/tongue.gif
   / First TBN Power Trac Owner #18
yes, i am alive and have experienced another of what not to do, start a new service (buy expensive equipment) unless you have the work. the weather has been such that my new topdresser and the service were not needed, except four times. not a good return on investment of a $5000.00 topdressing machine.
oh well, for the last two years we been cutting grass until the first snow storm. this year we are at 99 inches of grass growth and still one more cut coming this week on about 15 larger properties.
yes, the green machine has greatly reduced my manuel labor cost, especially during tree removal and leaf cleanup work.
belated happy thanks giving to all.
   / First TBN Power Trac Owner #20
</font><font color="blue" class="small">( yes, the green machine has greatly reduced my manuel labor cost, especially during tree removal and leaf cleanup work.
)</font>
I'm curious how you are using the power trac for leaf cleanup, as I have major leaf issues in my area, too.
OnTheWeb
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2012 CATERPILLAR 308E CR EXCAVATOR (A52707)
2012 CATERPILLAR...
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
UNUSED PABREAK BE232 HYD BACKHOE DIGGER ARM (A57193)
UNUSED PABREAK...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
