First refill to check fuel consumption. ....Wow...!!!
   / First refill to check fuel consumption. ....Wow...!!! #1
ATP
Land Between the Lakes
John Deere 3038e and LS K 5047
Just refilled tractor (ls k 5047) for first time since purchase. 1st tank thru averaged 3/4 gallon per hour....
If I had not seen it on the gauge I would not have believed it!!
The tractor was used 70% for Bush hogging. .. half of that was weeds/grass 4ft tall...rest was pasture...2 to 3ft tall.
I ran an 8ft disc for an hour and 5ft tiller for an hour too..
So pretty good average of work. Rest was loader work.
   / First refill to check fuel consumption. ....Wow...!!! #2
What hp is it? My figures on the JD 4010 (18.5 hp) were 0.46 gph over 660 hours. The JD 1025R seemed a direct hp proration to 0.61 gph. First tankful on the 2025R (about 1 hp more than the 1025) was around 0.75 gph, too much by hp proration. Think the 1st tankful on the 1025 was a tad high, too.
My fuel usage gem is the Isuzu diesel generator. I figured, at around 2 kwh average, that it would consume about 0.2 gph from the fuel charts published on this 12.5 kw unit. That's about what it has run now for near 3 years running. Still not to the 50 hour oil change yet. Oil still almost like new.
Ralph
Ralph
   / First refill to check fuel consumption. ....Wow...!!! #3
The K5047 is a 47HP utility tractor.
I haven't checked fuel consumption, just refill when needed.
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A59228)
2010 Turfco...
2018 CATERPILLAR 323 EXCAVATOR (A60429)
2018 CATERPILLAR...
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56438)
2019 Krause...
2012 Ford F-250 4x4 Pickup Truck (A60460)
2012 Ford F-250...
