First Question
   / First Question #1
Thumper & Buttercup
North Dakota
NH T2220
Any suggestions for a joystick that is
straight instead of the bent metal one
that comes on the T2220.
Thanks Mark
   / First Question #2
Mark, the threads on the joystick and the jam nut that locks it into the joystick valve are 7/16" - 20 threads per inch. That is the same size as the T2230 (class III) tractors that have a slightly different joystick and also a deluxe joystick that will bolt right up to your valve. The deluxe joystick has a wire and buttons that would not be used on your tractor, but you might like either of these joysticks more.
I think if I were in your position, I would not spend $100+ dollars on another joystick, but rather, I'd go to a welding shop and get them to make me a rod with the right threads on each end and try it out. Heck, you might cut a section of 7/16-20 all-thread and give it a try before going to something more durable. You also might take your joystick and get it heated and bent to a shape more to your liking. It's really easy to remove the joystick. If you lift the rubber boot, all you do is loosen the jam nut and then turn the joystick until it unscrews.
   / First Question
Thanks jinman,
I was looking at the IPB and thought it
was easy, the sizes help alot, now something
else to look at while I've got her in the warm
shop:).
Mark
2014 COTTRELL CX-09LS2 AUTO HAULER (A51222)
2014 COTTRELL...
2018 Toro Sand Pro Bunker Rake with Edger Broom (A49461)
2018 Toro Sand Pro...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
1974 Ih Farmall 1066 Tractor (A50514)
1974 Ih Farmall...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
