First problem with my 5 year old Kioti DK45
   / First problem with my 5 year old Kioti DK45 #1
grsthegreat
Super Star Member
north idaho
Kioti DK45SE hst cab
Old reliable let me down last weekend. I was out chipping limbs for about 4 hours on Sunday when i descided i best refuel tractor. Drove to shop to refuel and i shut down tractor.
it wouldnt restart. Turned over with lots of power but no start.
engine was hot so i went in and had lunch. Later i found that 25 amp stop solonoid fuse was blown. Replaced fuse and it immediately blew again. Ok, not good.
all wires were clean, no chew marks. I pulled stop solonoid off of injector pump and tractor fired right up.
i tested all 3 wires on solonoid and im getting short between all of them. I also see some molten solder pieces near one terminal.
i called and ordered new solonoid and should be here today. I hope thats the only problem. I have 4 generators coming in and need the tractor to unload.
I guess i can run tractor and manually shut it down but dont like running it with the solonoid removed as now theres a open hole where the solonoid sat.
Replaced part, new fuse.......runs great again.
Thank god. Generators arrive tomorrow
   / First problem with my 5 year old Kioti DK45 #3
Weird that the solenoid coil lost insulation. Oh well. Could have been worse. Wasn't a whole lot of trouble for an electrician to fix. :) :thumbsup:
   / First problem with my 5 year old Kioti DK45 #4
This is the first confirmed SS failure I can recall.
   / First problem with my 5 year old Kioti DK45 #5
I was thinking the same thing. Several guys have bought them, but later discovered it was the Fuel Stop Solenoid Relay on the firewall that was defective not the SS itself. But the things are up there on the hot injector pump with a lot of vibration, so I guess I should not be surprised to hear of a failed one.
I ran the tests shown in workshop manual and the resistance test failed. After seing the solder runs in terminals, i knew there was a problem.
Ill post pics later.
Tractor works fine now
   / First problem with my 5 year old Kioti DK45 #7
The price of the workshop manual was just recouped in the first repair! :thumbsup:
PAIR OF MINI RUBBER TRACKS (A57193)
PAIR OF MINI...
UNUSED FUTURE FT 72 PRO 72" HYD MULCHER (A57193)
UNUSED FUTURE FT...
10' HYD POLE SAW (A57192)
10' HYD POLE SAW...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
UNUSED GRASSROOTS IMPLEMENT 5' BOX BLADE (A57192)
UNUSED GRASSROOTS...
2016 Chevy Tahoe (A56859)
2016 Chevy Tahoe...
