First Post
/ First Post #1
DarlingFarmRoad
641 Workmaster
Hi mine is a 641 Workmaster with a Sherman Step up/down aux. trans. Over the weekend Ive noticed some noise that I think I've correctly diagnosed as coming from sherman unit...I've never added oil to the sherman in the 15+ years I've owned it and am not sure how to??? I did find a post about adding oil when installing but surely theres a way without breaking the tractor in half??? Can anyone point me in the right direction??
/ First Post #2
Welcome to the forum!
While I am far from a follower of the old fords, I have s friend that had a “_N” not sure now if it was a 8 or 9, but it had a Sherman aftermarket. It was one I believe his grandfather had bought new and had been past down through the family. I believe it went to a nephew but not sure now.
As best I recall from his, it was mounted internal with the exception of a shift lever coming through the housing. If this is correct and it may well not be!, then unless there is a removal plate to access the internals, I fear you will have to split the tractor to access the internal Sherman unit.
Good Luck with it!
One of the reasons he let it go to a different family member was the Sherman unit effected the speed of the PTO.
/ First Post
thanks Mr. CoyPatton...kinda just what I'm afraid...Hopeing Mr. Kirk NJ will chime in with some better news for me...hes got a bunch of youtubes but none mention service of these units
/ First Post #4
I put a NOS Ford brand 3 spd. aux. in my '65 Ford 2000, straight 4 speed about 20 years ago. It was a million to one shot I even found one, new in the box, at a little country Ford dealer, we happened to be working by at the time.
To install, the front input shaft had to be removed, then the aux. trans. fit in that space. IIRC, once you fill that transmission, oil from the main transmission keeps the oil level up to snuff, coming through the front main shaft ball bearing, basically making it a common reservoir.
I remember there is a lip seal between the two, to supposedly seal the connection. I installed the OEM seal that was in the box, even though it was 30 y.o. at the time, yet seemed pliable. Sadly, a few weeks later I noticed a slight leak coming from the weep hole underneath.
I put it back in the shop, split the tractor again, and replaced that seal. A few weeks later, had the same thing. Both seals were properly installed, just figured it was a design flaw, and will be a leaker. I'd advise to check the oil level in your main transmission.
I'm not sure if that Ford transmission was designed on the Sherman trans. or not. This one has a Ford part number on the transmission case, and is still listed in the parts list for the '65 and newer 2000 and I believe 3000, Schematic, Manuals, Specifications and Diagrams for Auxiliary transmission, over & under (accessory) | New Holland AG | MyCNHi US Store although a lot of the parts are N/A anymore.
I did keep the input shaft, and housing in case the transmission ever failed for some reason, and would just have to live with the straight 4 speed transmission, which is geared pretty fast for a lot of work. That's the reason I ended up with it anyway. The previous owner said it was too fast, for using a rotary cutter in heavy weeds. It was 35 years old, and only had around 1300 hours on it. At first, I thought maybe he just hadn't operated tractors much, but soon found out he was correct. That's when my search for the aux. transmission started. Thank goodness for the internet..!!
I'm also thinking if your getting a noise from the transmission, it could be a bearing failure, and could be repaired. Hopefully it would be a common bearing. If beyond that, find a good used input shaft/housing, and go with the straight transmission, although it may be quite a bit faster than what you're used to now. I'm thinking the over/under was at 10% on this one.
/ First Post #5
A properly installed Sherman gets its oil from the main transmission there is no way to check or add oil to it once it is installed.
/ First Post
thanks Mr DJ...just what I had feared...
/ First Post
thanks Mr. John...just what I feared...looks like a busy weekend and hopefully just a bad bearing...
(2) CHROME STEP BARS (A64276)
(2) CHROME STEP...
PRIEFERT PORTABLE CATTLE SQUEEZE CHUTE (A64277)
PRIEFERT PORTABLE...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
LOAD OUT AND SHIPPING (A65583)
LOAD OUT AND...
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
2022 EZ-GO ELITE...
