First post!...2000 series B&S filter replacement
/ First post!...2000 series B&S filter replacement #1
1Gunner
Cub Cadet 2000
First post::thumbsup:
I'm changing the filter on a 1999 16hp B&S V twin 2000 series tractor.
What filter cross references with the stock filter?
/ First post!...2000 series B&S filter replacement #2
might be an engine oil filter OEM p/n on a decal under the hood or listed in the tractor's manual... once you have that, should be able to cross-reference at most auto parts stores or use one of the online x-ref lists offered by the major filter mfgrs... might also be able to pull off that number off the filter on the engine now.
/ First post!...2000 series B&S filter replacement #3
I assume this is a replacement engine, custom job in this tractor?
As far as I know, there's no such animal as a Cub Cadet 2K series with a Briggs & Stratton engine in it, single or V-twin. They're all Kohler aside from some with an Onan single single cyl OHV.
Joel
Joel, it is my dad's 2000 series model 2165 yard tractor and yes it came with a 16hp Vtwin B&S Vanguard engine.
I have a 2185 yard tractor, which DOES have a Kohler Vtwin.
I found a NAPA Gold filter.
Thank you for your reply, but may want to check your information source.
/ First post!...2000 series B&S filter replacement #6
Man I'm loosing it!
Thanks guys.
I should have known better considering I almost purchased a new left-over 2100 series back in 2005, that had a Briggs Vanguard 18hp V-twin in it. It was a 2004 model year. The only reason I didn't get it, is it had a 42" deck. I really wanted a 3-blade 44-48" at the time.
Anyhoo, glad you got the filter thing worked out. I know many of the Briggs twins have the filter mounted at an angle that might interfere with stuff if you wanted a larger filter like the Motorcraft FL400's I usually recommend for Kohler V-twins.
Joel
/ First post!...2000 series B&S filter replacement #7
Try a NAPA 1348, it's for a Toyota but it will fit a 2165. You may need to turn the drain line depending or put it on the other side. Better filter and it's cheaper.
/ First post!...2000 series B&S filter replacement #8
Any filter that fits a 91 Saturn car they only had one motor fits that engine and a Koehler command
THUNDER CREEK FUEL TRAILER (A67714)
THUNDER CREEK FUEL...
2018 MAGNUS MINI VAC TRAILER (A67714)
2018 MAGNUS MINI...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
2009 FREIGHTLINER M2 Slick Line (A67714)
2009 FREIGHTLINER...
Unused 2022 USA Attachments EB1024 24in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2022 USA...
2007 PETERBILT 378(INOPERABLE) (A67714)
2007 PETERBILT...
