First post!...2000 series B&S filter replacement
   / First post!...2000 series B&S filter replacement #1
1Gunner
Cub Cadet 2000
First post::thumbsup:
I'm changing the filter on a 1999 16hp B&S V twin 2000 series tractor.
What filter cross references with the stock filter?
   / First post!...2000 series B&S filter replacement #2
might be an engine oil filter OEM p/n on a decal under the hood or listed in the tractor's manual... once you have that, should be able to cross-reference at most auto parts stores or use one of the online x-ref lists offered by the major filter mfgrs... might also be able to pull off that number off the filter on the engine now.
   / First post!...2000 series B&S filter replacement #3
I assume this is a replacement engine, custom job in this tractor?
As far as I know, there's no such animal as a Cub Cadet 2K series with a Briggs & Stratton engine in it, single or V-twin. They're all Kohler aside from some with an Onan single single cyl OHV.
Joel
Joel, it is my dad's 2000 series model 2165 yard tractor and yes it came with a 16hp Vtwin B&S Vanguard engine.
I have a 2185 yard tractor, which DOES have a Kohler Vtwin.
I found a NAPA Gold filter.
Thank you for your reply, but may want to check your information source.
   / First post!...2000 series B&S filter replacement #6
Man I'm loosing it!
Thanks guys.
I should have known better considering I almost purchased a new left-over 2100 series back in 2005, that had a Briggs Vanguard 18hp V-twin in it. It was a 2004 model year. The only reason I didn't get it, is it had a 42" deck. I really wanted a 3-blade 44-48" at the time.
Anyhoo, glad you got the filter thing worked out. I know many of the Briggs twins have the filter mounted at an angle that might interfere with stuff if you wanted a larger filter like the Motorcraft FL400's I usually recommend for Kohler V-twins.
Joel
   / First post!...2000 series B&S filter replacement #7
Try a NAPA 1348, it's for a Toyota but it will fit a 2165. You may need to turn the drain line depending or put it on the other side. Better filter and it's cheaper.
   / First post!...2000 series B&S filter replacement #8
Any filter that fits a 91 Saturn car they only had one motor fits that engine and a Koehler command
12 foot two person Terry aluminum John boat (A50324)
12 foot two person...
2001 DITCH WITCH JT1720 DIRECTIONAL DRILL (A51242)
2001 DITCH WITCH...
New Holland TS6.120 4WD Agricultural Tractor (A50322)
New Holland...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
Wolverine Quick Attach Screening Bucket (A50514)
Wolverine Quick...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52128)
2017 Yale GLC050VX...
