First leak from my 2400H...help!
   / First leak from my 2400H...help! #1
TXCOMT
Texas!
Branson 2400H
Evening from North Texas!
I found a puddle of thick green fluid under my front axle the other day...after further inspection this afternoon, it seems like it’s coming from where the driveshaft meets the front axle. Is this something I can fix or does it need a lift to the nearest shop?
TXCOMT
Never mind...found out this will be covered by Branson’s warranty, so off to the dealer it goes!
TXCOMT
   / First leak from my 2400H...help! #3
Just curious but my 2400H has a plastic tube around that drive shaft that connects via rubber boot to front axle. Did they eliminate the plastic boot on the newer models. I always figured it was to prevent grass from wrapping around the drive shaft.
hopefully quick and simple fix
I don’t see one but maybe they changed it to a steel tube?
TXCOMT
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2012 Ford Expedition XLT SUV (A51694)
2012 Ford...
2003 Isuzu NPR-HD Truck, VIN # JALC4B14637000853 (A51572)
2003 Isuzu NPR-HD...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
