First leak from my 2400H...help!
   / First leak from my 2400H...help! #1
TXCOMT
Bronze Member
Texas!
Branson 2400H
Evening from North Texas!
I found a puddle of thick green fluid under my front axle the other day...after further inspection this afternoon, it seems like it’s coming from where the driveshaft meets the front axle. Is this something I can fix or does it need a lift to the nearest shop?
TXCOMT
Never mind...found out this will be covered by Branson’s warranty, so off to the dealer it goes!
TXCOMT
   / First leak from my 2400H...help! #3
Just curious but my 2400H has a plastic tube around that drive shaft that connects via rubber boot to front axle. Did they eliminate the plastic boot on the newer models. I always figured it was to prevent grass from wrapping around the drive shaft.
hopefully quick and simple fix
I don’t see one but maybe they changed it to a steel tube?
TXCOMT
2022 INTERNATIONAL MV607 (A52472)
2022 INTERNATIONAL...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
WOODS RC60.20 LOT NUMBER 88 (A53084)
WOODS RC60.20 LOT...
