KWentling
Veteran Member
- Joined
- Jun 22, 2002
- Messages
- 1,149
- Location
- Rozet, Wyoming
- Tractor
- Kubota BX22, Kubota ZD21, Kubota M7060
Sounds like you have it going your way. As far as synthetics goes, I use them in my diesel trucks for the cold starting properties. The little Kubota sleeps in a heated shop so it has dino oil in the engine but the SUDT in the transmission/hydraulics. My big tractor (1977 Case 1070) probably had never seen a day inside other then in for repairs before I owned it. It still resides outside 90% of the time. It has dino oil but doesn't see much use in the winter and I have a block heater on it so so starting isn't much of an issue. If you aren't going for extended oil drains or need the extreme weather properties, I personally don't see the need to spend the extra $$$ for synthetic engine oils. Modern oils are pretty darn good these days and how many people run something till it wears out such that synthetics superior wear properties would make a difference? Full time farmers who put on hundreds of hours in a year probably, but that doesn't include many here. Kind of the same deal for synthetics in transmissions. I use it because it flows better in the cold. I suppose there may be some advantages in efficiency and rolling resistance but I don't see that as a big factor. If it makes you feel good putting the best oil available in your tractor, by all means spend the extra for the synthetic. Nothing wrong with that. Right or wrong, that's how I see it.
Kim
Kim
