First DPF !!!!
/ First DPF !!!! #1
Doughknob
ohio
Deere X500, Bobcat CT4045
I feel like one of the 'initiated' now. I had my first active DPF regen today! The tractor stunk something terrible. At first I did not know what was happening and thought
a mouse nest or some wiring had caught fire or such. Then I saw the DPF light on. I let it do its thing while I pushed snow with the bucket and the light eventually went off and the smell stopped just before I decided to park it. I am so happy.....................!!! 🕺
/ First DPF !!!! #2
It should become seamless. Only way you'll know is the light is on. If you are working the engine it will regen without effect. If not, it may derate the engine to create enough exhaust heat to do it's job. To minimize the effect increase the engine speed, even if not needed, during the regen so it doesn't have to derate. Regen will just become a part of your life with the tractor. Enjoy!!!
/ First DPF !!!! #3
The first regen stunk pretty bad on mine, second not so much. So far it seems like much ado about nothing. Most of the people carrying most on about T4 seem to be those who don't have it.
/ First DPF !!!! #4
The under 75 hp machines that don’t have DEF are pretty reliable. The above 75 hp machines with def are far worse.
2022 EZ-GO ELITE...
2015 Texas Trailers FB3330B 33ft. 22 Ton T/A Tag Trailer (A64556)
2015 Texas...
John Deere 700 H Dozer (A62679)
John Deere 700 H...
2007 Ford Explorer Crew Cab Pickup Truck (A64556)
2007 Ford Explorer...
Bush Hog 176 3Pt Blade (A66408)
Bush Hog 176 3Pt...
2000 Hino (A64194)
2000 Hino (A64194)
