First Dealer Test......
/ First Dealer Test...... #21
Whether it's for my tractor or backhoe both dealers ask if I'm in a hurry for next day shipping & pay or wait for their regular shipments which are Tue. and Thur. generally which will be no extra cost.
That would of been nice to have an option.
In the future I will be using online retailers on items that I can. If it is dealer only item, I will ask next time if I will be charged shipping up front. If so, just because I'm pissed I will call another dealer and have it shipped to me, unless it needs to be dealer installed.
I'm rather pissed about this.
Small businesses wonder why it is hard to stay afloat sometimes. This is a prime example, why be up front and when you can market up everything you have by 20-30% then charge shipping then charge another 3% cor credit card use. This is a dealership, not a specialty shop and even at that they still don't charge shipping.
/ First Dealer Test...... #23
Charging for shipping seems to be common in todays parts world. I went to my Ferris dealer (also sells Mahindra ) for a deck belt for my mower. He didn't have any, nor did a dealer 30 miles away. Seems rather stupid for a dealer who sells 2-3 brands of mowers not to have a common wear item in stock. It is really common for me, have to replace it every year so far due to breakage about every 50 hours. I have a Craftsman ZTR that is 5years old and only replaced belt once when I got some trash under the deck, belt jumped off and cut it in the process. Anyway, I had to pay shipping to get the belt and 7 day delivery too. I think he may be charging me for 2-3day shipping($17) and waiting for his weekly delivery of parts for the belt to come.
Back to the issue, IMO, dealers should stock all common service items for all models that they sell. I always buy at least one each of the 50 hour service items when I buy the tractor. As a note, I would not stop using the tractor if dealer has no service items. Just get them changed ASAP when the filters come in.
I would also be looking at a OEM replacement from NAPA or other supplier.
I made it a point to get the parts numbers from them on these filters. I also checked to make sure they were not painted over before I left so I could see the numbers on the filters. I plan to use NAPA or online in the future now that I have the correct part number.
This is all a learning experience, I call it the "Stupid Tax".
/ First Dealer Test...... #25
When I bought my Kioti last yr. I bought an oil filter at the same time and went with it to Napa & asked them to get out one of their 's that matched when I held them side by side the Kioti filter was much heavier. For a $1 more I think I stick to the OEM.
/ First Dealer Test...... #26
I've never bought a hydraulic hose at a dealer.....there are 3-4 places around here, including NAPA auto parts stores that make them on the spot. Given they always have to SEE the fittings on what I bring in, I really think ordering most hoses online would be a disaster.
My FEL on the Yanmar has blown so many hoses, the last time I went to the hydraulic shop, I had a complete set of extra hoses made (less than you'd think, several of them are the same fitting/length) so I can repair quick and get back to work.....they always blow right in the middle of what you are doing.
Hydraulic trouble I've had as much as anything is cylinders leaking, the top 'curl' cylinders to be exact. One blew the rod end completely out of the tube, damaging the threads so it wasn't repairable. Under warranty, they replaced it....with one that leaked down slowly (didn't do that before replacing that one).
Finally got bad enough, (and out of warranty) I simply bought a new cylinder from the dealer, and a couple of packing kits....new cylinder about $140.....packing kits $80 ea....go figure that one ? Now the other side is leaking enough it leaves a circle of fluid on the shop floor, so I guess it's time to try one of the packing kits on the spare, bad, cylinder I have. Apparently, Yanmar uses the cheapest supplier of hydraulic cylinders/etc....only way I can explain that much failure on a 4 year old tractor. Owned a New Holland tractor for 14 years and never had a bad cylinder on it, and only a couple of hose replacements in that time.
/ First Dealer Test...... #27
TnAndy Have you ever checked your pressure relief setting you shouldn't be having that much of an issue unless your relief was way high. Sometimes they can stick and not open.
/ First Dealer Test...... #28
So you feel its Ok to overcharge me by 3 to 5 percent when I buy something with cash or a check so that you can give the credit card company that 3 to 5percent when they don't pay the business owner the exact amount charged?
I actually prefer to deal with business that don't pass their credit card business loss off on their hole customer base by inflating all their prices so that the one customer who doesn't understand how it all works wont have to pay more for the same thing even with the vendor making that much less compared to the cash or check customer.
I would agree if their prices were not already over inflated to begin with. But in this case, jacked up prices, had to pay for shipping on items that should of been in stock to begin with, and a 3% surcharge because of a card. When no where in the place is there a sign that says there is a surcharge, or I would of been a cash/check customer to begin with.
I couldn't care less about the next guy coming to buy something. I am more concerned with feeling ripped off and then seeing more charges added to the bill. When this should of been disclosed from the beginning. I asked when they would have the parts and said I was not in a hurry. So regular shipment from Kioti to dealer was fine. My fault for not asking and theirs for not saying it, either way, won't be using them unless I have warranty issues. Period!
/ First Dealer Test...... #30
I understand all your frustration. You haven't hit on the single issue that would have put me over the top!!!! You just bought a new tractor from them!!!!! As someone else mentioned, they should have chased down the filter information for you that day or next day at the latest. And they certainly should not have charged you shipping to get your filters!!!
You mentioned that you thought you had a good dealer. My friend, you do not, never did.
I'm worked up and it doesn't even cost me anything..... :mad:
2008 Mercury 25HP 3-Cylinder Boat Motor (A59231)
2008 Mercury 25HP...
2024 JOHN DEERE 325G SKID STEER (A62129)
2024 JOHN DEERE...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
2016 Freightliner M2 106 Altec AM50 50ft. Bucket Truck (A59230)
2016 Freightliner...
John Deere 3025E (A53317)
John Deere 3025E...
