First codes
/ First codes #1
chas0218
Southern Tier N.Y.
LS MT235E
So I was running the backhoe today digging out some drainage and had a couple codes pop up and the yellow triangle with exclamation mark. The codes flashed quick and were off after 5 or 6 blinks. I was just about to raise the rpm before they flashed and once the rpm came up they disappeared.
I have not had a regen yet at 30 hours and no regen lights have came on to indicate there has been one running. I think the one code had an 11 and the other 04.
/ First codes #2
I have no idea what the codes are. Does your owners manual have a list of the most common codes? Call your dealer and ask where you can get a list of codes.
/ First codes
Talked to the dealer and he said that all codes flash f11 followed by 04 then whatever else. I didn't get the whatever else of the codes because I bumped the throttle up in that time he said. These came on just before a regen cycle so not sure if it had to do with that or not. Either way it didn't go into limp mode and 1st regen at 30 hours so I must be doing something right.
/ First codes #4
I wouldnt worry too much about it if they went away. Could be air in the fuel line that got pushed though by the higher rpm. Keep an eye on it though. Let us know if they come back, especially if they stay!
2yd. Skid Steer Trash Hopper (A65640)
2yd. Skid Steer...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A65054)
(INOP)1989 NISSAN...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
Land honor Mini Skid Steer (A60352)
Land honor Mini...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
New/Unused AGROTK Wheel Balancer (A65583)
New/Unused AGROTK...
