Firewood pallets
/ Firewood pallets #1
aarolar
Platinum Member
Augusta Ga
Kubota MX4800
Stole Sawyer Robs idea with his firewood pallets and managed to finally get one filled up and the Ol MX did manage to pick it up probably a little less than a 1/2 cord there.
/ Firewood pallets #2
Getting some good use out of your tractor for sure!!!!
/ Firewood pallets
You have no idea, I have gotten more work done around here in 3 weeks than I could have in 3 months without it.
/ Firewood pallets #4
I'm glad it's working out for you!!!
/ Firewood pallets #5
2WD! Pretty rare around these parts (this forum), but it sounds like it's not a hindrance for you.
Probably saves enough coin to buy a car....well, not really...
Sure looks nice. Obviously ballast is even more important with 2wd, but still very functional.
/ Firewood pallets #6
I was well on my way to adulthood before I saw my first 4wd tractor with a loader. )
/ Firewood pallets #7
I'm going to build a firewood pallet.
/ Firewood pallets #8
I just "borrowed" Rob's idea and built 2 of them. I spent more than I had hoped on ($80) each and that's buying r/s Hemlock 2x4 -8's for only $2.05. I did "run up" the cost using those good GRK screws instead of nails, hoping to keep them sturdy for years.
This was my initial fill up & wanted to see how they stacked. They are 5'x6' and about 3'6" tall but only have about 91 cu/ft of wood with a space for air flow between the 2 rows. If I convert to this, I'm going to need at least a dozen:eek:
/ Firewood pallets #9
Looking good Rusty! But I'm struggling though to see how you have $80 in each... did you have to pay for the pallets?
/ Firewood pallets
That's where I'm at right now mine don't cost anywhere near 80$ a piece but it's still a pretty decent investment for something I'm unsure of how many years it'll last. If they hold up 5 years or so I'm fine but every time I've used pallets for firewood they rotted within a year or two. I did add treated 4x4 for the dunnage on the bottom in place of the untreated so we will see.
/ Firewood pallets #11
Me too. Back when 4x4 wasn't widely available I think we learned how to work with what we had, and got by nicely. But 4x4 is sure an improvement
/ Firewood pallets #12
Yep. I don't own a motorized vehicle without 4wd. :)
/ Firewood pallets #13
I was thinking of using regular pallets with side posts nailed on, then setting 4x4s under to keep the pallet off the ground. Set a few of those side by side, and put an old sheet of metal roofing on top.
/ Firewood pallets #14
Me too! I built the whole thing, no free pallets involved. I cut my wood at 26" and that just does not work with the pallet's that I come across for free. The 2x4's 8'- $2.05 10'- $3.33 12' $4 then there's 2-12' pt and a $35 box of screws, and that doesn't count the other screw's I had and several tubes of const. glue also on hand. All the lumber was cut in half and virtually zero waste. The Hemlock seem's to be pretty durable outside, I have a sawbuck that's been outside for about 7-8 years now with no trouble, and with a cover on these box's they will get no direct rain. I'm telling myself that I should get 10 years use at least.
I saw a member's alternate design on another forum that also involves no pallets. It really is a simple design and should be $20-30, it's only a single row but I can live with that for a $50 savings. I'll build a couple of these to see how I like them.
/ Firewood pallets
Care to share?
Got the second pallet made and almost filled gonna take one more to get all the wood I have cut off the ground.
/ Firewood pallets
/ Firewood pallets #18
Yes, the design is so simple it makes me feel foolish with my complicated expensive "pallets". Maybe I should have worked for the govt.:laughing:
/ Firewood pallets
Mee too plus much easier on my loader.
/ Firewood pallets
Thinking about it Rustyiron I'm not sure it's going to be cheaper, sure they are cheaper per unit but you'll need twice as many units...
