Firewall insulation for JD 318 thanks to John Lang
   / Firewall insulation for JD 318 thanks to John Lang #1
Everhard
Mulmur, Ontario
Kioti Ck2510
Hi all, just wanted to post up a quick comment to say I got the firewall insulation kit from John Lang, and he does a great job. Very good directions, good prompt service.
And for those you that haven't replaced or looked at the state of your firewall insulation it's a good idea to check it. I had bought this tractor used a little over a couple years ago, and didn't realise it was even missing at the time! I'm hoping this will help the motor run longer. It seems to be a decent running engine.
E.
   / Firewall insulation for JD 318 thanks to John Lang #2
can u share the link please?
Simplest is contact John via email - langjohn260@gmail.com
Note he's got 2 options, either you fully removed the engine and then install the insulation as one piece or if you're not removing the engine (my case) he has a 3 piece option.
E.
Lift Station Pumps (A49461)
Lift Station Pumps...
2019 Chevrolet Tahoe SUV (A49461)
2019 Chevrolet...
WASTE OIL TANK (A50854)
WASTE OIL TANK...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
NANCE UNDERGROUND CONDUIT BOX (A50854)
NANCE UNDERGROUND...
2025 LandHonor LHR-EW20000 20,000lb Electric Cable Winch (A49461)
2025 LandHonor...
