Fireplace sets off smoke alarm with no fire
   / Fireplace sets off smoke alarm with no fire #1
DrRod
Platinum Member
Ellicott City, MD - Farm in Orbisonia PA (south ce
John Deere 4110
Greetings,
My son just moved into a house. The fireplace hasn't been used in years. Today he opens the damper -- builds no fire -- and the smoke alarm upstairs goes off. A bit later he tries again and within a few minutes the smoke alarm goes off again. I can't think of a reason for this. Can anyone give us a clue?
   / Fireplace sets off smoke alarm with no fire #2
Fly ash? Stuff got stirred up?
I have smoke detectors in a hallway within twenty feet of a smoky fireplace (with cracked heatalator as well) that never go off. Only a foot or so bulkhead separating hall and living room.
Just curious. Are the detectors photo or ionization type?
   / Fireplace sets off smoke alarm with no fire #3
How old are the detectors? They have a 8-10 max life span. If 8, I'd replace them. Takes about 2 mins each and that's a new pig tail and base too. If they are still good, get a can of compressed air and blow them out. They accumulate dust and stuff that causes false alarms. Make sure the batteries are new. 9v is the standard. If it's a wired system they say every 6 months, if no times of extended power outage, you can go to 12 (my opinion).
Opening the damper without building a fire could of stirred up some fine ash to spread thru the house. It causing a detector to go off upstairs is unusual. Could just be a coincidence. Also, it could've been a detector in the fire place room that activated and it set all of them off.
Brett
   / Fireplace sets off smoke alarm with no fire #4
Cold chimney is down drafting, and the house is sucking in dirty air from there. If he has any bath, kitchen, or water heater exhaust fans running that encourages the down draft even more.
   / Fireplace sets off smoke alarm with no fire #6
Could it be the opposite? Could the chimney be pulling air out and the water heater could be exhausting into the house?
   / Fireplace sets off smoke alarm with no fire #7
Want weird - my TV remote control can set of my smoke alarm.
   / Fireplace sets off smoke alarm with no fire #8
I doubt it. I can't open the stove doors at the same time my kitchen stove vent is running or it sucks in smoke.
   / Fireplace sets off smoke alarm with no fire #9
I had a customer call me all irritated. Smoke detectors wouldn't shut off. Several phone calls later and he was still more irritated. Finally I had him power down the security system and disconnect the back up battery. The noise persisted.
He (A Doctor) called back a while later to explain that he found a childs toy in a toy box making all the noise. I don't think any apology was ever offered.
   / Fireplace sets off smoke alarm with no fire #10
Op,
The detector itself is probably filthy inside, and the sudden air movement is stirring dust up from inside the detector. I would recommend your son just replace them all to start with, since he just moved in. Just the humble opinion of a NICET certified fire alarm tech (commercial systems).
2012 Cadillac SRX (A50324)
2012 Cadillac SRX...
2014 Ford E-350 Cargo Van (A50323)
2014 Ford E-350...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
Quick Attach 80" Rock Screening Bucket (A50514)
Quick Attach 80"...
2002 Wilson Hopper Bottom Trailer (A50514)
2002 Wilson Hopper...
